Home > For Sale > Aluminium Flywheel,
As above, as used on the Don last year , origionally i made it with an alloy ringear , but had just about worn out , so i have fitted a new verto steel ringear , it weights 6lbs 13,1/2oz, or 3.1kg
perfect working order , i only changed it "because i can"
I'll start it at £150 delivered uk,
carl
this is pre verto isnt it carl?
Verto, as in later metro, so much better than thoese rattly fooking inertia bendix shitty setups,
verto as in the whole flywheel? or are we talking ring gear?
if its a verto flywheel, ill have it
Ah sorry confusion, i'd forgot people actually still used full verto setups, YUK.
its a early pre verto flywheel but with a pre engaged ringear,
cheers carl it is a yuky verto flywheel im after lol
I doubt you would see one of those in aluminium. MED do a nice steel one *wink*
Maybe Mr Austin could fashion a nice lightweight verto item for the guys on here *wink*
it did cross my mind, John, now go away and do some reserch for me,
Err I can give you a verto flywheel if you don't have one seeing as you think they are yukky.
*happy*
There must be more weight to come off the med flywheel, that rear looks heavy.
Ti flywheel?
