Home > Help Needed / General Tech Chat > boost help, only got 3.5 psi
eden7842
Member #: 8852
leicestershire
hey
got a problem with my boost, its only going to 0.25 bar on the gauge (tim) its a standard t3 setup with a bleed valve plumbed in.
any ideas please? thanks
bleed more signal off?
eden7842
Member #: 8852
leicestershire
am i being a fool? would i be right in saying my standard actuator will only do 3.5psi?
ive opened my bleed valve right up
with a bleed valve your current actuator should let you run whatever boost you want. Is your boost gauge ok? try winding it up with a foot pump to make sure its not buggered.
EDIT: Not whatever you want but definately more than 3.5psi.
Edited by John on 25th Apr, 2010.
eden7842
Member #: 8852
leicestershire
i assume so as i got no power increase when i opend the bleed valve, it works fine in - pressure and then + when boost comes in.
my downpipe is blowing big time, could this affect it?
metroturbo
Member #: 989
North Yorkshire
Have you plumbed your bleed valve into the correct place?
eden7842
Member #: 8852
leicestershire
thinks so, ive got the 2 connections off my turbo, 1 blanked then the other to the bleed valve then to the actuator.
sound right?
Johnny
Member #: 6926
Accrington
close the valve to increase boost? with mine you have to tighten it to give you more boost, but be carefull, sometimes (depending on which valve you have) it can jump right up with just half a turn.
revving it on the drive wont give you accurate boost figures (if any) you will need to drive it under some load
see what that does :)
Edited by Johnny on 25th Apr, 2010.
yes
sound right?
Don't think so. Check this out:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=257121
eden7842
Member #: 8852
leicestershire
mine works by opening it to let the actuator recive pressure, it this right?
jamz
Member #: 2292
Tool
Herne Bay, kent
i thought you ahd to have one from the turbo to the bleed valve and one to atmosphere.
cant beat a good blowout.
eden7842
Member #: 8852
leicestershire
yeah i know what you mean jamz, anyone to comferm this?
stefaz
Member #: 1656
stoke-on-trent
the diagram paul linked to is spot on
eden7842
Member #: 8852
leicestershire
right il pipe it up like that and try it out
thanks
pot_dan
Member #: 326
bradford, west yorks
if that doesn't work for you, once my air pipe to the filter collapsed i on itself and wouldn't get more than 3-4 psi..
just a thought
Dan
http://turbominis.co.uk/car/105/
eden7842
Member #: 8852
leicestershire
all sorted now id just plumbed my bleed valve in wrong like a noob. thanks for the help
