Home > General Chat > %CO
just at mot test centre now i think its failed on it CO is there any specific reason that could make it high its at 6.9 i think
cheers
Mixture too rich at idle.
If it's a HIF44 just wind the mix screw out until it comes down to a legal level.
yep did fail, emitions and front suby mount of front panel 'is no longer there'
tbh i think the rolling road is best for it as the fueling is set by my ass dyno and a narrow band afr gauge and fueling over 2krpm is good
I've got an gunosons emmisions gauge thingy you can borow when I get back from my brother.
I'm guessing this is the clubby and I need to take my finger out and remove my front valance....
ill have to take you up on that offer, no rush on the valance though im just gonna weld it, lots of weld it *evil*
it's in cambridge, hopefully get it back on thursday
my aem wideband has just turned up so i might be able use that,
if you get it back before the weekend let me know please, cheers :)
might this help?
Get the wideband on, sorted.
thats excellent joey cheers
wideband is on it idles at afr of 12.3 its shown some really interesting results though, the flat spot just off idle is off the scale lean and what i though was valve bounce at 6300 is off the scale lean aswell
it gradually leans out as the revs rise under load ( till 6300)
and on application of WOT bellow 2500 it goes round to about 17afr then pulls to 12-13afr
any one able to decode that? lol needle is BDL mg engined hif(44)maybe 38 it s basically stage one as far as im aware
ill fudge it through the mot then think about a rr sesh at Northampton
