| Home > Help Needed / General Tech Chat > a series gearset into a+ casing? | |||||||
26th Apr, 2010 at 09:51:54pm
hi, i just need a bit of confirmation. i have been offered a 1300 gt close ratio a series gearbox. its the 4 syncro type.
26th Apr, 2010 at 09:55:29pm
yes, it will go,
26th Apr, 2010 at 09:58:54pm
thanks for getting back to me. |
26th Apr, 2010 at 10:38:28pm
On 26th Apr, 2010 mini13 said:
yes, it will go, only problem may be getting the main shaft assy in, the A series as a smaller diameter but wider bearing between the 1st and 3rd motion shafts, as a result the case is notched slightly so get it in, can be done to the A+ case with a file. This only applies to the 3sync boxes. Remember that the remote reverse idler won't fit in the rod box. On 13th Jul, 2012 Ben H said:
26th Apr, 2010 at 10:52:43pm
have bought this now. not bad for 100 quid. |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
26th Apr, 2010 at 11:23:32pm
On 26th Apr, 2010 Vegard said:
This only applies to the 3sync boxes. Remember that the remote reverse idler won't fit in the rod box. A mate of me had to enlarge the slot over the 1st motion's bearing to put a 14mm pre-A+ mainshaft into a late A+ gearbox (DAM5626)? http://img384.imageshack.us/img384/2051/dscf0005qu9.jpg - or am I missunderstanding something here? :) But maybe he's lucky and got one of those very late GT boxes with 2 step layshaft & 18mm nose bearing (DAM3168 laygear) :) MiniSpares sell conversion bearings with a sleeve to run pre A+ idler gears with a A+ case. http://minispares.com/Product.aspx?ty=pb&pid=38305 Edited by Asphalt on 26th Apr, 2010. [X] nail here for new monitor |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
27th Apr, 2010 at 12:13:24am
*Cheeky post*
Metric is for people who can't do fractions. |
27th Apr, 2010 at 08:31:32am
The A mainshaft is indeed longer, but there shouldn't be a problem. I cannot recall I had difficulties at least. On 13th Jul, 2012 Ben H said:
27th Apr, 2010 at 11:12:38am
Those 5626 casting seem to 'fluctuate' quite a bit anyway :) There are probably some you get away with, and with some you don't. Interesting. [X] nail here for new monitor |
27th Apr, 2010 at 11:22:28am
cheers chaps. will be collecting it in the next few months, when i get time. i will let you know how it goes when the time comes to put it into the later a plus casing.
27th Apr, 2010 at 02:26:59pm
Im running an A gearset in an A+ box. The cutout doesn't need to be all that big, this is mine.
