| Home > Help Needed / General Tech Chat > Diff failure...? | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
29th Apr, 2010 at 01:45:16pm
Hi!
[X] nail here for new monitor |
29th Apr, 2010 at 01:52:52pm
Smashed planet wheels, no great suprise.
29th Apr, 2010 at 01:52:53pm
Diff = Fail
29th Apr, 2010 at 02:15:20pm
Thought so... :( Thanks guys! :) Engine out time... Might stick the SPVP3 in whilst I'm at it. :)
29th Apr, 2010 at 02:17:29pm
WTF is a SPVP3?
Edited by John on 29th Apr, 2010. If something is worth doing, it's worth doing half of. |
29th Apr, 2010 at 03:54:00pm
i would opt for a minispares x pin diff,
29th Apr, 2010 at 05:37:55pm
Yes, I'm actually considering that now...
29th Apr, 2010 at 05:42:33pm
On 29th Apr, 2010 Asphalt said:
What makes me scratch my head a bit is that I rebuild the diff about 4000 miles ago. With a 'competiton' pin & bushed planetary gears. Turned freely and had no play when I assembled it. Must have done something wrong? That's the problem then, assuming that you use the Minispares competion pin. The bushed planetary gears should not be used with the competition pin. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Apr, 2010 at 05:57:40pm
On 29th Apr, 2010 Paul S said:
That's the problem then, assuming that you use the Minispares competion pin. The bushed planetary gears should not be used with the competition pin. I don't know where the pin is from (my parts dealer sells MiniSport & 'Spares stuff), but it was a 'kit' consisting of new thrust washers, bushed gears & pin. It's not impossible he mixed them, though. I'll see what's wrong tomorrow :) Hmmm - just had a look: according to the bill it was C-BTA166. So not the 'competition' but 'uprated' pin. Sorry! [X] nail here for new monitor |
72 Posts Member #: 6792 Advanced Member |
29th Apr, 2010 at 08:30:37pm
Hi Jan,
30th Apr, 2010 at 05:22:40pm
On 29th Apr, 2010 Tom Fenton said:
Smashed planet wheels, no great suprise. Nail on head!
[edit] The unsmashed gear's bush is 0.2mm wider! Looks like it was too soft and opened up under load? Would explain the 'crown' of brass that build up...?
Edited by Asphalt on 30th Apr, 2010. [X] nail here for new monitor |
30th Apr, 2010 at 05:58:09pm
I'd check the diff housing. If it's worn, the planet gears will not mesh properly on the output shaft gears. Picture? On 13th Jul, 2012 Ben H said:
30th Apr, 2010 at 06:01:31pm
It's worn now. However, it was like new when I installed it! I took extra care to select a good sphere/diff cage...
30th Apr, 2010 at 07:08:28pm
is it a standard diff? if so i have a housing in good condition PM me if you want it. or a minisport 4 pin diff Edited by Johnny on 30th Apr, 2010. |
1st May, 2010 at 02:13:57pm
Thanks for the offer! I have spare diff here, allready build (intuition!?) :)
1st May, 2010 at 03:48:22pm
Fit a 4 pin diff.
1st May, 2010 at 04:51:18pm
Ah I can't decide... @Johnny: PM sent! :)
1st May, 2010 at 06:46:39pm
thats not a diff failure,
1st May, 2010 at 07:00:09pm
Mmmh - nothing a tube of JB Weld can't fix [X] nail here for new monitor |
1st May, 2010 at 07:15:43pm
On 1st May, 2010 fastcarl said:
thats not a diff failure, this is what i call a failure,lol ![]() good effort!
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
1st May, 2010 at 09:32:07pm
my mate had that happen to the box casing, it was leaking oil like hell and finaly spat the final drive off pulling out of concentric pumps car park, it was a 4 pin diff as well, turned out one of the roll pins had failed and let a half pin slowly find freedom.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
1st May, 2010 at 10:20:22pm
On 1st May, 2010 MONSTER HEDGEHOG said:
my mate had that happen to the box casing, it was leaking oil like hell and finaly spat the final drive off pulling out of concentric pumps car park, it was a 4 pin diff as well, turned out one of the roll pins had failed and let a half pin slowly find freedom. The casing in my original Withy 4 pin diff were soft, and the pins ended up wobbling free lol Took out the casing, 1st gear and reverse when it went. Even Tran-X couldnt beat a diff pin. 9.85 @ 145mph
good effort!
