Home > Technical Chat > Belt drive or chain?
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
As per title. Which would people prefer/think is better for a turbo a-series? I'm specifically looking at this: http://www.7ent.com/detail.cfm?pageid=3786
Too expensive for what it is, or is it worth it for the adjustability?
Thanks in advance!
-James
That's very expensive. Talk to matty about belt drives *hehe!*
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Just ask Joe (mini13) *happy*
Is that in US dollars? If so, it's rediculous money. Swiftune or MED vernier duplex works without fault.
On 30th Apr, 2010 Rod S said:
Gary's description is best
*Punch*
Id stick with silent chain type. Its nit actually a chain with teeth as such.
i like them too, but theyre bloody hefty bits of kit, weight a tonne
Si P
Member #: 912
North Yorkshire
I've got my hands on one of these.
http://www.med-engineering.co.uk/product_d...99&vlang_id=542
Not fitted it yet but no chian or belt.
But might be a right pain in the arse to set-up. I will report my findings once fitted.
Si
Si
Nice si, now get that engine built
rick
madcatminis
Member #: 5327
Dudley, West mids
Those gears are easy to set up. You just have to drill a couple of extra holes for the dowels that locate the idler gear and jobs a good un. I had a set on my 1330. Originally from slark. They where the muts nuts!!!
Si P
Member #: 912
North Yorkshire
Its in you bugger. lol
I'm onto my next engine. How about you...?
Si
Si
rick
Si P
Member #: 912
North Yorkshire
Thats good to here.
Sorry for thread diversion
Si
Am I missing something here? lol
My belt drive is all well and good. *happy*
I'd try and get hold of one of the gear type timing assemblies. Someone on here had one fitted that looked really nice...can't remember who now though? *Confused*
Edited by matty on 30th Apr, 2010.
miniswordsman
Member #: 6558
so the med cam gear kit, it eliminates the belt, or chain altogether?
yep
miniswordsman
Member #: 6558
ok. wow then. For some reason that just never occured to me. That might be the way to go then. The motor build is pretty much a no expense spared build, so that'll get added to the list I think...
EricsAmerica
Member #: 7891
Annapolis, MD USA
The MED set has an idler gear similar to your drop gears to eliminate chains and belts...
Saw that they now have an "improved" version....
Looks the business to me, but never had any experience. I just got my belt kit (not the super fancy one) from Seven today 8-) that they say runs thier Can-Am car problem free. Also got the new KAD silicon damper too :)
Right now I'm N.A., but possibly turbo on a spare motor on my Austin 1300 (America).
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
EricsAmerica
Member #: 7891
Annapolis, MD USA
P.S.....been reading the forum for a while now....great info!!!
Eric
i like the bullshit bit on the MED site about redesigning, its a fooking wheel ,just how did they manage to redesign it, bullshit speil , they are just hyjacking bryan Slarks idea and added some spin,
miniswordsman
Member #: 6558
lol. yeah. Which would you recommend Carl? A slark or the med? I'm thinking the slark kit might be like hens teeth over here.
MED and Slark re engineered the cog drive together. Steve identified that the teeth bottomed out as they meshed which caused the problems that Slark encountered.
Im very interested in it myself - will sound awesomely loud and will have virtually no timing scatter
turbominivanman
Member #: 1504
Westbury, Wiltshire
Nibble has a gear kit fitted. Think it was an MED one.
Are you able to comment Neil ?
Richard.
nibble36
Member #: 4273
stoke on trent
sorry not replyed just got back from riv run
yep i got this to http://www.med-engineering.co.uk/product_d...99&vlang_id=542
its easy set up you get 1 deg on the holes and 7deg on the teeth i set mine to 110deg as used a MED T3 CAM
i used 2 DTI one on the piston and one on the push rod got it 110 deg bang on just keep checking it till yor happy,
the worst thing it drilling the block for the roll pins you need get it on a good pedestal drill and i cut the feeler gauge and put it in each side of the middle gear to get the gap RIGHT ( O YES YOU HAVE TO FILE THE BOLT HOLES OUT SO YOU GET SOME MOVEMENT ON THE MIDDLE GEAR TO SET THE GAP RIGHT)
they not noisy but make the engine sound like a bike engine
good luck mate
Edited by nibble36 on 3rd May, 2010.
Chain drive....cheap, simple and oddly enough they work !!
So really...is there actually a real and genuine need to change it ?
nibble36
Member #: 4273
stoke on trent
just rememberd i got pics lol
i don't think so , but thats advertising for you, it convinces the technically inadaquete thay there lives are not complete unless they purchase the lasted must have product,
gear drive would be usable if you were in a ultra close racing endurance racing championship and the extra 1 hp saved over a ten day race r may not gain you a place
carl
