Home > Help Needed / General Tech Chat > Where is best to measure boost from??
locht
Member #: 8874
Hi all
Im getting my first turbo mini on the road and was wondering where is the best place to measure boost
When i measure it from the plenum or the comp housing of the turbo im getting 13 psi but when measured from the inlet manifold im getting 5psi.
Is it normal to lose this much pressure across the carb?
Any help will be greatly appriciated
Always measure from the manifold as this is the boost that your engine is running.
As for the dramatic drop between plenum and inlet I can't answer that.
As above, manifold. What actuator/turbo are you running?
metroturbo
Member #: 989
North Yorkshire
Were you measuring boost at full throttle? If not, you will get a difference between plenum pressure and manifold pressure.
locht
Member #: 8874
Im running a garrett t2 with the standard internal actuator but slightly bigger internals
Both measurements where made at full throttle
Even when boost is increased to 20 psi at turbo im still only getting 6-7 psi at the engine
Carb seems to be either restricting the flow or bleeding it but have just done a seal kit in the carb as well
evolotion
Member #: 83
Glasgow, Scotland
are you actually measuring from the manifold, or one of the hose barbs on teh carb?
Denis O'Brien.
locht
Member #: 8874
out of the top of the manifold where there was a banjo bolt
That's odd. Any photos of the piping?
sounds like you have a boost leak somewhere
locht
Member #: 8874
Thats what i was thinking
I will go take some pics and post them it is a very std setup though
EDIT: Wrong thread...
Edited by apbellamy on 7th May, 2010.
