Home > Help Needed / General Tech Chat > oil feed and return
Grimmy
Member #: 8892
i am having to move my exhuast housing round which is going to make the oil feed and return not vertical opposed from each other.
is it an apsolute must that feed is at the top and return on the bottom?
many thanks
Nick
Member #: 154
Midlands
doesn't the exhaust housing move seperately to the central core?
If on a Garrett they all move independantly, so you should be able to keep it verticle.
Not all other manufacturers build in the same freedom.
Grimmy
Member #: 8892
many thanks for your replys.
i was thinking about the feed at the top and return at the bottom thing. would it not be benificial to have them at downward angle at say 50 degrees so that some oil is allways in the core or is it a case of get the oil in and out as quick as possible for cooling?
It needs to get out. For lots of reasons.
