Home > Help Needed / General Tech Chat > help needed before l2b !
blister
Member #: 2590
Croydon
anyone with minispares alloy calipers on here? if so what wheels have you got over them?
t@z
Member #: 452
Chester, UK
is there anything specific you want to know, ie what wheels you can use, can you borrow someones wheels etc?
www.twitter.com/lilpinkiy
MarkGTT
Member #: 1194
Shropshire.
you need 12" wheels or above for the alloy 4 pots but 10's will fit over the alloy billet calipers.
blister
Member #: 2590
Croydon
sadly have non i can borrow to try and fit,
these are the calipers i have
http://www.minispares.com/Product.aspx?ty=...id=38325&title=
ultralights or superlights both 10x6
I've got these with 13" wheels.
I believe some 10" split rims fit the non-vented variety (although I've never seen anyone try so tbc). Other than that it's 12" or above.
blister
Member #: 2590
Croydon
oh! i bought the kit thinking as it says for 10" wheels i could fit all :S erm wow,
bit stuck now really had my heart set on a set of 10x6 ultra lights
not sure what to do now
Ah, sorry didn't look at the link properly. They are the 7.5" jobbies.
blister
Member #: 2590
Croydon
ahhhh so whats that mean i got a 10 inch steel wheel on my phoenix i will try if that doesnt fit does that mean no 10 will fit?
What hubs abd disks do you have?
If you've fitted these to an 8.4" setup then 10" wheels won't fit.
If you've fitted them to a 7.5" setup then they will.
A mate of mine is running 10" minilites 10x6 over minispares 4 pots!
Did the box not have a leaflet inside it ???
I looked at these in DSN about 18months ago (they sell on some of MiniSpares specialist items) and the leaflet inside said they fit with most 10 wheels but not some early cast alloys and listed those where there "might" be a problem.
If they are no longer putting that leaflet in the box perhaps they have improved the fit.
blister
Member #: 2590
Croydon
i have the 7.5 inch discs and matching pads and there wasnt any leaflets in the box,
i will have to have a word with huddersfield later on today
