Home > Wanted > 6x10 to fill miglia arches
jamz
Member #: 2292
Tool
Herne Bay, kent
revos, minilights, rare wheels, etc anything. needs a higer offset though so dished wheels.
Edited by jamz on 19th May, 2010.
cant beat a good blowout.
my 6x10 wellers are 1/2 inch off filling mig arches, so there is a thought
(there not for sale btw lol)
jamz
Member #: 2292
Tool
Herne Bay, kent
haha. well i think im going to order some 6x10 ultralights form minisport. there offset-3 so should fill them enough. seing as some of the migs use et0 and 6.5 wide. that is only a 1/4 of inch differene from center which i could alwasyp ut 5 mm spacers just to make it lok abit better.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I would rather trim the inside of the arches than fit a spacer
On 30th Apr, 2010 Rod S said:
Gary's description is best
jamz
Member #: 2292
Tool
Herne Bay, kent
this is true. are sapcers really a bad idea. even 5mm?
MarkGTT
Member #: 1194
Shropshire.
spacer will be fine.
GaryOS
Member #: 2810
Dublin, Ireland
5mm is fine as you probably don't need longer studs but I would just trim the arches on principal
don't forget that miglia tyres overhand a 7" rim by about an inch,
Yes, the problem is getting the tyre to fill the arch.
165 profile 10s look lost under a wide Miglia arch, even on a 7.5" rim.
I think that if you space it to look any good, then you will foul up the front geometry. Best fit a narrower arch and be safe.
jamz
Member #: 2292
Tool
Herne Bay, kent
mmm maybe i need some wide group 2's or something then.
