Home > A-Series EFI / Injection > wiring up aftermarket ecu and wiring loom
matt-atude
Member #: 8913
seaford, east sussex
hi all. im running a 1293 with eaton supercharger. i am going to run it with fuel injection on an emerald ecu.
the only problem is that my current wiring loom is for a carb. what is the best way to wire the ecu loom to the mini one. i.e main relay what amp relay how many pins, what fuel relay what amp how many pin. should i run a relay for the fuel injectors or would that run off the main realy? is there any general wire diagrams? or is there any one who has don this sort of loom conversion before?
cheers matt
the megasquirt site(s) is good for info like this,
typically automotive relays are 25-35 amps and are fairly generic.
Edited by Joe C on 19th May, 2010.
I would have thought Emerald would have posted or provided a suitable (and safe) wiring diagram.
The Megasquirt one that Joe (mini13) has shown is quite generic so quite safe - it's what I have done but I've added an extra relay for the widebands and datalogging and another for the starter motor - but surely Emerald should tell you ???
actually thats a good point,
in the emerald manual there is a wiring diagram, it should be downloadable form thir website
MrOz
Member #: 5007
Crazyhill, Livi
Yeah, download the manual from here
http://www.emeraldm3d.com/em_manuals.html
I've attached the relevent pages from it - just for information.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
matt-atude
Member #: 8913
i haven't resieved the ecu yet should be coming friday morning but i do have the part wiring loom, at the moment im just trying to sort the basic loom structure and what components are needed i.e the relays. i haven't done any wiring on this scale before so i want to make sure i do it right.
thanks for the wire diagram it is very helpful its made things quite alot more clearer. :)
matt
no probs,
on that megasquirt diagram not that there are connection numbers for the relays, they tie up with the pins on automotive relays *wink*
Is the Emerald even capable of running a 5 port successfully ?
Wet manifold / electronic SU ..... *happy*
It won't have the code for siamese port injection.
But then define "successfully" :)
Matt, re. your original question about integrating it into the standard (carb) loom, I wouldn't.
It's all new stuff and the only bit of the existing loom that becomes redundant is the feed to the coil/dizzy (assuming Emerald will be running a proper wasted spark or CoP system) and you can just tape that out of the way.
I made a completely seperate loom for the injection, widebands, data logging etc with its own modular relays and fuses and it just takes its power from the main battery cable at the starter solenoid.
Edited by Rod S on 20th May, 2010.
with a charger you can inject before the charger and they are fairly happy. thats what v max do.
jbelanger
Member #: 831
Montreal, Canada
Have you or VMax or anyone else checked the AFR distribution between cylinders? If so, I'd like to see the actual data. But I doubt anyone's bothered to do it because it ran "well enough".
Not to mention that the supercharger manufacturer recommends not to have fuel going through it...
Jean
http://www.jbperf.com/
Don't you remember Andy500's problems with fuel distribution?
http://www.turbominis.co.uk/forums/index.p...tid=242798&fr=0
The pictures on the second page are the give away.
