Home > Help Needed / General Tech Chat > power suddenly shoot out after 5000rpm?
jom
Member #: 6003
Every time i put my foot down i can feel power suddenly increase after 5000RPM. i havent tried higher than 6000rpm, so i not sure about after 6000. AND during the engine speed up, some where between 4000rpm to 5000rpm. i can feel engine become weaker . something wrong with fueling?
Edited by jom on 24th May, 2010.
jom
Member #: 6003
Forgot to say. im using 276cam, T3 turbo. 1293CC
What happens to the boost/afr when the occurs?
jom
Member #: 6003
i set the boost at 8psi, and i think 8psi can be reached at 4000rpm, not sure now , i need have look later.
Has it ever been 'normal'?
jom
Member #: 6003
i just chaged the distributor to metro turbo one last week, and the problem started after i change. i was using 1275 cooper electric distributor with 4psi boost. and the engine was normal to me , no power sudden shoot out .
what do you mean 'shoot out' Do you mean that when you get to 4-5k you get lots of boost and it accelerates more quickly? If you where using a different dizzy then the advance curve potentially wouldn't suit a turboed engine. Now you have a turbo dizzy you will be getting a closer matched advance to your engine and potentially more power.
jom
Member #: 6003
no ,the boost can stay at 8psi after about 4000rpm, but power suddenlly out from 5000rpm. its just like a point. however boost stay same, so im thinking about fueling and timing
doesnt the clock work dizzy pull in its high speed advance about 4500rpm maybe yours is sticky and coming in fast and late. Makeing more power in an instant
jom
Member #: 6003
now im thinking about the needle and the spring, they may cause too rich before 5000rpm? i didnt change them, they re all origal one.
With such a vague description of the problem...and general lack of info about your setup...how the hell is anyone meant to help !!
