Home > General Chat > polishing compounds
MarkGTT
Member #: 1194
Shropshire.
Hi, what do you use for finishing paint?
I previously used farecla - G6 i think.. but im not sure if this is the best thing to get rid of 2000 grit wet sanding, is it too coarse?
cheers, Mark
turboestate
Member #: 362
durham area
Hi mate i always use 2000 grit wet sanding followed buy farecla G3 then some farecla G10 to remove any swirls, then a good coat of wax to seal the fresh paint hope this helps just what ive found works well
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
MarkGTT
Member #: 1194
Shropshire.
is the G3 a coarser grade the the G6? i guess the number implies this..
i never did flat and polish my car, is it to late 10 years after painting it
Never to late to flat and polish it mate, although it looks OK without....!
turboestate
Member #: 362
durham area
yep G3 is slightly courser than the G6 mate
______
/___|_____
_ (@)___(@)
MarkGTT
Member #: 1194
Shropshire.
cheers - i will get some ordered then.
