| Home > Wanted > lightening conrods | |||||||
25th May, 2010 at 07:44:21am
as above in good condition |
25th May, 2010 at 07:57:22am
Mr austin will lighten your rods, give him a pm. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th May, 2010 at 08:07:48am
I'd be weary of buying used worked rod's. They only last for so long - ask JF.
25th May, 2010 at 09:46:04am
On 25th May, 2010 apbellamy said:
I'd be weary of buying used worked rod's. They only last for so long - ask JF. Did he have one fail? On 7th Oct, 2010 5haneJ said:
25th May, 2010 at 09:49:50am
Yes, poked right through the front of his block... On 11th Feb, 2015 robert said:
25th May, 2010 at 01:37:35pm
i picked my force worked rods up the other day, just a bit more fettling and they will be good to go, carls work is top notch Yes i moved to the darkside |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
25th May, 2010 at 09:26:14pm
i can vouch for the hole lol, was shocked when i saw it! wasnt the crank cracked aswell?
Yes, poked right through the front of his block... Edited by Rick.SPI on 25th May, 2010. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
25th May, 2010 at 10:27:30pm
The rods I got from Carl had two holes in them... On 13th Jul, 2012 Ben H said:
25th May, 2010 at 10:56:03pm
Are you sure they didn't have 4 holes? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th May, 2010 at 10:58:39pm
On 25th May, 2010 matty said:
Are you sure they didn't have 4 holes? ![]() Some of the holes had been plugged... On 13th Jul, 2012 Ben H said:
25th May, 2010 at 11:01:09pm
On 25th May, 2010 Vegard said:
