Home > Help Needed / General Tech Chat > Verto and pre verto clutch plates.
shane
Member #: 1246
Lowestoft, Suffolk.
The cluth on the mini has started to slip with "enthusiastic" driving when running anything over .8bar. I have in the garage two plates with a little life left in them, both AP items, I know one was from my std metro clutch, the other from one of my dead engines with a pre verto, but I cant work out which is which. Any help greatfull.
Shane
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
just use the lighter one,
the springed is verto the non one is pre verto ,
the metro turbo was a verto mecanism with a non verto solid plate
i was wondering this same question last night, so fab does that make them interchangeable? verto - pre verto
I never thought that they were interchangeable.
I would use the one with the biggest diameter.
They are interchangeable, as far as I remember I've used both in the past.
fab
Member #: 100
Paris' suburb
they're completely interchangeable, though if using a verto in a pre verto mecanism, you'll have to use a 180mm one (pre 1994), as their isn't enough diam (have to machine it) to take the 190mm plate.
Any verto mecanism from 1980 will take a 190mm plate..
hope it's clear
fabrice
Still learning, great info though.
Can you get a 190mm plate without springs I wonder? I would guess not.
i think there is a thread by robert with plate types and diameters kicking about somewhere
and cheers for the info guys
Edited by Brett on 28th May, 2010.
Use the one without springs. They are the weakest link...I found out the hard/expensive way. :(
http://www.minispares.com/Product.aspx?ty=...id=38496&title=
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks for that guys, I had wondered if they was interchangable as they both looked of similar but couldnt lay my hands on a rule or vernier to double check,
Shane
Chuck a paddle plate in it
