| Home > Help Needed / General Tech Chat > Midget 1275 Block | |||||||
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
28th May, 2010 at 03:28:29pm
My step dad pulled a block from a midget out of his garage the other day and said i can use it for the mini BUT before i go full steam ahead and get it worked ready:
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
28th May, 2010 at 08:16:25pm
I,ve done it the other way round which is probably more difficult, but the real difference is in the rear main bearing cap. Have a lokk and decide if you can keep the Midget one (preferred option) or if you need to use a mini one, which should, technically, be line bored to match. If its to be a hi-po engine then you cant take any chances. |
29th May, 2010 at 02:23:36pm
so this is the only difference that could provide any issues, so if I can use the original main bearing cap its usualble? Gaball said:
Carbon but plug? |
29th May, 2010 at 02:25:37pm
Carbon but plug? |
31st May, 2010 at 07:10:19am
I took a chance and changed the cap without having it line bored - but then I am a bit of a chancer anyway -certainly not recommended.
31st May, 2010 at 09:55:30am
I'd just use a mini block.
31st May, 2010 at 10:48:57am
On 31st May, 2010 minimole23 said:
I'd just use a mini block. not particularly helpful, but it saves the hassle. I agree. Also, the inline boys have started converting Mini blocks because they are getting scarce. On 13th Jul, 2012 Ben H said:
31st May, 2010 at 11:33:37am
I agree, but can I have the Midget block, please ?. |
31st May, 2010 at 01:47:13pm
On 31st May, 2010 tadge44 said:
I agree, but can I have the Midget block, please ?. oh david ...you chancer lol Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st May, 2010 at 05:42:39pm
I was going to say I've got a 1275 A+ block I'd be willing to swap for it. Isambard Kingdom Brunel said:
1st Jun, 2010 at 10:06:34am
On 31st May, 2010 Rob H said:
I was going to say I've got a 1275 A+ block I'd be willing to swap for it. well as long as its in decent nick then id be up for that :) PM me Gaball said:
Carbon but plug? |
