Home > Help Needed / General Tech Chat > Rediculous oil consumption
Owen
Member #: 6496
Somerset
1380 N/A engine
Right, the 1380 i've got in my mini at the moment is costing me more in oil than in petrol! Arg. Basically i'm using about 3 litres a week.
A bit of background on the motor...
The bottom end had a rebuild about 4000 miles ago with new rings etc. The head is a SRE race head but with unknown mileage. All breathers are vented to atmousphere. The motor doesn't leak oil.
It smokes like an absolute trooper apart from when you're cruising at very light throttle.
I have done a compression test and am getting readings of about 15 bar at WOT, does this rule the rings out?
I also noticed that the head is not fitted with stem seals on the valves, would it actually make it that bad?
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
Scruffy
Member #: 328
Seaford Rise, South Australia
Compression test will tell you nothing - a cylinder leakage test is where its at!
On 5th Sep, 2011 Vegard said:
I'd try putting some stem seals on first.
you really would hav eto go some to loose 3 litres of oil down the valve stems in a week,
but it is possible, i had an All agro that used a gallon a week,
it did not really show bad signs of oil consumption out of the exhaust but if i let it over run for more than 5 seconds the whole world dissapeared in a cloud of smoke on reapplication of the loud pedal, my engine was sucking some serious oil down the stems,
try the overrun trick and see what the signs are out the back,
carl
Carl S
Member #: 1761
Stalker
What oil are you using Owen? I recently switched over to fully mineral 20W50 and the mini is drinking it down like a good un so i'm re-introducing semi-synthetic oil, as the engine never used a drop before.
turbo hogster
Member #: 178
stowmaket suffolk
well if it smokes that bad on all but prtial throttle then a complete rebuild with new block looks on the cards
mowog
Member #: 6792
I seriously doubt its stem seals as Owen says it doesn't smoke on light throttle.
It would be rings and / or bores. The A series is not spectacular in regards of ring to bore sealing and when you go to these bigger bores, the bores actually flex quite a bit which doesn't help.
A ring(s) may have broken (detonation?) and / or poor breaking in would also do it.
philc
Member #: 1346
bromsgrove
are the plugs covered in oil? it may also be worth popping the head off to have a look and check the gap between the rings and bore. pure some oil into the bore and see what happens
Owen
Member #: 6496
Somerset
Carl, I'm using 20/50 mineral atm.
I took the plugs out, they aren't oily, but are covered in carbon also, the electrodes appear to have almost disintergrated on all 4 plugs :S .
I have to whip the head off now as the head gasket has just gone urg.
On another note, the engine never smoked until this head was put on it.
det?
whatt cr?
Edited by Brett on 31st May, 2010.
Owen
Member #: 6496
Somerset
I hope it's not det, i've been running with the dizzy slightly retarded until she goes on the rollers (again). It's also overfuelling massively.
The head has 19cc chambers and the pistons iirc have 9cc dish. I think it's around the 12.5:1 mark.
P.s. I didn't build this motor, it is out of my mates car so you can't go telling me i've put the wrong bits on it LOL.
Bingo. Eureeka. Nail on head. There is your answer.
a cr of 12.5 on pump gas is enough to make a det monster imo, and id expect piston damage, at least broken rings or wiped out head gasket if its took the plugs the head gasket would have had a beating*happy*
edit : you can only suppress det so much with the timing, i would try stay well within the limit on a dizzy
Owen
Member #: 6496
Somerset
Well I pulled the head today...
The HG was gone big time between 2 and 3.
Also there is a LOT of slap in all 4 pistons, and the cross hatchings on the bores are non existant...(considering this was rebuilt 4000 miles ago and not has not been hammered this doesn't seem too good???)
Also, I found 2 broken inner valve springs, and 2 bent pushrods.
So i've decided to change it for a 998. Seems a bit 2 steps back, but I'm not going to replace the rings as it's not my engine.
tadge44
Member #: 2500
Buckinghamshire
My engine also smoked excessively whilst overfuelling and has virtually stopped now that its set up properly-bore wash is the term, I believe ?
Mind you, it leaks more than its ever burned !
