| Home > Help Needed / General Tech Chat > Oxygen Sensor | |||||||
568 Posts Member #: 102 Post Whore Pennsylvania USA |
2nd Feb, 2005 at 04:09:58pm
Whats the best place to mount an oxygen sensor and what read outs should i be looking for ie lean or rich? |
![]() 265 Posts Member #: 68 Senior Member Coventry |
2nd Feb, 2005 at 04:50:19pm
i fitted mine in the Y piece after the join of the 2 pipes on my carb car.
Edited by mini-marauder on 2nd Feb, 2005. Sooperdooperturbocooperexpertengineering! |
2nd Feb, 2005 at 04:53:25pm
easiest place is to put it just in the downpipe i guess. not got one on mine but will do this year.
2nd Feb, 2005 at 05:55:40pm
Mines in the end of the downpipe.
2nd Feb, 2005 at 07:28:07pm
Ours is about half way between the turbo and the downpipe bend. It seemed the best place, where there was enough space.
http://www.twin-turbo.co.uk
2nd Feb, 2005 at 08:34:45pm
Should it be perfect or should it be leaner or richer? |
2nd Feb, 2005 at 08:54:18pm
Turbo engines are 'safest' between11 and 11.5 on lambda - don't know what that is in volts though... On 17th Nov, 2014 Tom Fenton said:
2nd Feb, 2005 at 08:55:05pm
oh, mine is in the elbow - the hotter the better!!! LOL! On 17th Nov, 2014 Tom Fenton said:
2nd Feb, 2005 at 10:13:26pm
Yeah I got a heated one so I'm not arsing about waiting for it to warm up. |
2nd Feb, 2005 at 10:28:21pm
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
2nd Feb, 2005 at 10:51:49pm
its a bosch 4 wire sensor. |
2nd Feb, 2005 at 11:01:27pm
Tech sheet for the WB bosch sensor.
2nd Feb, 2005 at 11:13:10pm
OK Now i'm getting confused. A lot of nice graphs though. Would it be best to keep it lower down on the down pipe like say at the bottom? |
3rd Feb, 2005 at 08:56:20am
put it half way along the down pipe :)
AlexF |
3rd Feb, 2005 at 10:12:49am
Cheers guys for all the help. |
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
3rd Feb, 2005 at 12:31:09pm
wide band sensor is quicker and more accurate (but as usual costs more), measured voltage is 0- 5 v i think ,air fuel ratio i would go for is 12:1 which equates to 6.5 percent CO under load , just put it somewhere the speed ramps wont attack it ! |
3rd Feb, 2005 at 05:21:34pm
My current sensor location and it's working a treat. Narrow Band 4 wire heated bosch sensor.
Edited by Doodmeister on 3rd Feb, 2005. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
3rd Feb, 2005 at 07:31:45pm
Doodmeister... what output / gauge are you using? Sooperdooperturbocooperexpertengineering! |
3rd Feb, 2005 at 07:41:25pm
what do you have you car set to. Rich or lean |
3rd Feb, 2005 at 09:23:23pm
Sensor and Gauge came of ebay.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
26th Feb, 2005 at 09:58:16pm
anyone know a place where you can buy a wideband sensor? i know narrowband ones are very easy to come by, but where the hell do widebands come from? new only? how much ??
And on the 7th day........... God created turbochargers! |
![]() 36 Posts Member #: 262 Member Netherlands |
26th Feb, 2005 at 10:30:59pm
For wideband O2 sensors, try http://www.wbo2.com/.
Op de bank beleef je geen avonturen |
) and i set it up using the innovatemotorsports LM-1 gauge. You can use the cheaper gauge from SI to tune but not being wideband it's not so easy. My cars running a 45 weber and seems to run rich under load and idles at midpoint say 14:1 (Green on the gauge) so not to bad.
