Home > Beginners Tech > recommend parts for n/a built
christ
Member #: 8918
hi well thanks to flo and the guys at sc i have decided to go n/a on the mini.
I have already decided on sc Billet Alloy CNC 7 Port Cylinder Head what else would you guys recommend ie what pistons,clutch and flywheel,gears etc basically any other parts as i want to collect these parts first and get everthing done at the same time i will be having the racing cam as its the same price.
Really want the mini geared up for acceleration rather then high speed as will be used on the road more then then the track.
Also i have no rev counter in my mini tahiti so how easy is it to add one of these
many thanks
chris
if your having a specialist components head id of though they would be best to suggest a spec
and maybe if the spec doesnt fall into place on its own S/C sould build it for you...
other than that all the answers are here for you all questions answered here, click me, click me!!!
Edited by Brett on 5th Jun, 2010.
Agreed, speak to John at SC, nice bloke, easy to get on with. He will be able to sort the lot for you
Paul
As above Johns a top chap and wont steer you wrong,
I suspect he'd say somthing like omega pistons, lightweight minispares flywheel and back plate, and probably a grey pressure plate as i think the orange might be a bit borderline.
adding a tacho should be easy, normally its a case of wiring in positive negative and a feed to the coil, are you going for SC's injection setup for this?
christ
Member #: 8918
yes mate was going for the complete set up head and engine management
christ
Member #: 8918
