Home > Technical Chat > Best Spark Plugs, 16psi & Megejolt
alaskanow0
Member #: 8466
Mansfield
Hi Guys,
Any ideas on best plugs for my newly build turbo engine. Im running T2 / T25 on mirage manifolds, Benross head, 1293 10cc omegas, Phase 2 Cam, custom IC & mega Jolt. Im looking at running 12psi normally and 16-18psi for the strip. I getting confused with B8ES, BP8ES & BPR8ES and then the range of platimum plugs, can anybody explain the difference?
What are you guys running and any recommendations on cheapest place to buy.
Heres a picture of my build so far, Ive just awaiting my manifolds from mirage, looking more and more likely I'll not be racing at Avonpark
thanks Matt
Edited by alaskanow0 on 3rd Jan, 2011.
shane
Member #: 1246
Lowestoft, Suffolk.
Your spec is similar to mine and I run NGK BP7ES, cant remember who on here advised me to run them and why, But I think I posted a thread on it?
Shane
shane
Member #: 1246
Lowestoft, Suffolk.
Ive searched but cant find it in the bookmarks ive made, may have been on my desktop not laptop, its either that or the altzimers is kicking in........ at least ive not got altzimers.
Shane
I believe you are supposed to use the BPR rather than BP's with megajolt...could be wrong though!
alaskanow0
Member #: 8466
Mansfield
I found the BPR8ES for £1.25 each on ebay, but they are listed for YAMAHA 900 XJ900F/S (83-94) NGK SPARK PLUG BPR8ES 3923.
http://cgi.ebay.co.uk/YAMAHA-900-XJ900F-S-...=item2a070495f7
Edited by alaskanow0 on 6th Jun, 2010.
wintersurferuk
Member #: 2208
hi mate you may want to make up a steady to stop your alternator form twisting. good luck with the plugs, im trying to do the same.
sorry forgot to say if its a denzo
Edited by wintersurferuk on 6th Jun, 2010.
alaskanow0
Member #: 8466
Mansfield
Thanks for the advise, I was thinking the same thing. I might even replaced the alternator with one from Brise, as its supported in 2 places and comes with brackets etc.
shane
Member #: 1246
Lowestoft, Suffolk.
I had this in my mind too, resistive is meant to reduce electrical noise or interference with ecu?
SHane
You need to use resistive plugs to help stop interference. So the ones with "R" in the number are the right ones.
alaskanow0
Member #: 8466
Mansfield
Thanks Phil,
which do you think BPR7's or BPR8's?
modifiedminis
Member #: 768
Fixing my car....
I was running B9EGV's in mine
I ran the BPR8ES plugs, but if the engine was slightly on the cold side, they would cause to engine to miss and jolt on acceleration. Im sure the BPR7ES plugs would of been better as it was mainly used on the road.
I would use 7's. You'll find anything colder will tend to foul easily on the road. I run sevens without issue, my boost is set to a minimum of 15psi.
Thats exactly what happened to mine, if I gave it a boot it would clear them up and it would be fine, and then slowly foul up again.
I ran i think 8's with absolutely no issues at all. The ones i used were escort RS turbo plugs. NGK copper core jobs or something. Still got a brand new set somewhere
I use 8s on the race car and 7s on the road car.
tadge44
Member #: 2500
Buckinghamshire
The A35 runs on 8,s no prob.8.5:1 CR and 12 psi - bit more when I see red, as at Avon maybe ?.
Idles and runs slow in traffic without any fouling probs
I wouldnt worry, mines bolted up the same and after a year running it ive had no issue what so ever.
wintersurferuk
Member #: 2208
mike probably right.
keep that one and use the standard bracket with a long threaded stud through it with a sleave over the top, i havent got any pics but oneeyed has some on his build thread, using an old tent pole for the sleave to stop it twisting, if it twists, im just making sure.
have a look at oneeyed,
http://www.turbominis.co.uk/forums/index.p...d=191396&fr=150
nice build mate by the way
CH007
Member #: 8863
sorry to hijack but are those omega 18cc dished? i am looking at these myself if so. Also if thats the case did you increase head cc or just go with standard and let pistons lower CR enough?
cheers
colin
I needed to reduce the chambers when using those pistons.
CH007
Member #: 8863
thanks for reply. Just getting ideas of work ahead :)
ARP's!! Nice!
