Home > Help Needed / General Tech Chat > What thread is the water temp probe in the cylinder head???
MiniVanMan
Member #: 5262
Yeovil, Somerset
Hey guys,
Does anyone know what the thread is for the water temp probe/stat thingy thats in the front of the cylinder head just below the thermostat housing?
Cheers in advance guys *happy*
i dont know for sure, but did know at one point as had an adapter made up for a modern guage
ill have a wild stab in the dark at 5/8 bsp?
5/8 BSP - that would be huge!
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
5/8 UNF, only know cos I recently bought an adapter for it.
MiniVanMan
Member #: 5262
Yeovil, Somerset
brilliant! so i think my auto meter gauge has a 3/8" NPT thread on it..
Do you know where about i could get a adapter thats 5/8UNF male into a 3/8NPT female??
P.S. that bmw looks shit hot *happy*
As above ^^^ 5/8" UNF
I've had to re-drill and tap a hose adapter to 5/8" UNF as I've sleeved the one in the head down to M12 X 1.5 for the ECU sender and the sleeve I made was also 5/8" UNF.
hammoj28turbo
Member #: 1502
Check the auto meter sendor thread. My autogauge had an 1/8 NPT and so do quite few sendors i think.
These are the guys who make the adaptor I have. I bought mine from Demon Tweeks but took ages to get the right one off them. Im sure other people sell them though or maybe go direct.
http://www.lmaperformance.com/Products/products.html
Cheers, they are ace machines.
Edited by hammoj28turbo on 7th Jun, 2010.
merlin motor sport do a 5/8UNF temp sensor that will do either oil or water. Costs about a tenner. probably easier the messing about with adaptors.
3/8" NPT is slightly bigger than 5/8" UNF so you can't sleeve it.
If you could buy (or just make) an adapter it would have to be stepped which would put the sender in a dead leg quite some way away from the water flow which would make the readings slow to respond and possibly read low.
A sandwich plate or hose adapter would be better.
or...
http://www.merlinmotorsport.co.uk/p4170/RA...oduct_info.html
hammoj28turbo
Member #: 1502
Is it ok to use other senders for your gauge? Would it not give a wrong reading?
The odd thing about the A series temperature sensor is that it is a parallel thread and seals on a taper at the base of the hole.
So your adapter needs to have the taper. Otherwise you end up with loads of PTFE tape like me.
hammoj28turbo
Member #: 1502
or you could use a dowty washer?
my autometer guages came with the correct adaptor
manifold
Member #: 1734
Lancaster
for my megasquirt temp sensor I just used one of these plumbed in the rad hose:
http://www.revotec.com/catalogue_HoseAdapters.asp
MiniVanMan
Member #: 5262
Yeovil, Somerset
[quote=Rod S,7th Jun, 2010]
quote]
Na my probe is really long (so long in fact that if i put it straight into the block it wouldnt go all the way in)..
Its definatly 3/8"NPT it says it on the instructions i got with the gauge AND when i tried it in the 5/8 hole in the head it was ever so slightly bigger.. Ive just got to get an adapter now i guess *oh well*
MiniVanMan
Member #: 5262
Yeovil, Somerset
P.S. its a mechanical gauge NOT electronic
http://www.autometer.com/cat_gaugedetail.aspx?gid=2556&sid=3
OK, but if it's a mechanical type is the (long) bulb small enough to go through a 5/8"UNF to 3/8"NPT adapter ???
The 5/8"UNF end of the adapter will have a fairly small bore just to give it enough wall thickness not to break.
MiniVanMan
Member #: 5262
Yeovil, Somerset
the bulb will just go through the 5/8UNF bolt ive already got in the head, JUST..
If it doesnt i rekon it will be so close that a little bit of filing wouldnt hurt :p
