| Home > Help Needed / General Tech Chat > Caliper slide flex | |||||||
7th Jun, 2010 at 11:05:28pm
Is this a normal amount of flex in the slider guides These are Fiesta calipers been on since some time in 07. You can feel the extra effort in the pedal as an extra "step". The first press pushed the pads out the extra pedal movement seems to be flexing the slider guides which cant be doing much for braking force. It seems to be a feature of the sliding caliper as there is rubber between the caliper mounting and the slider bolt.
8th Jun, 2010 at 07:53:20am
It might help to hold the camera steady On 13th Jul, 2012 Ben H said:
8th Jun, 2010 at 08:02:35am
looks like one abit sticky piston to me, not calliper flex Yes i moved to the darkside |
8th Jun, 2010 at 09:44:05am
sorry I was trying to get very close...
8th Jun, 2010 at 09:46:08am
the piston and guides seem to move freely the guides are clean and have the grease in that came with the calipers. I'm wondering if the MC on the mini is smaller than the fiesta so you feel it more at the pedal. I run a supercharger and I don't care the TB is on the wrong side.
The only flexing I saw was in your arms.
