| Home > Help Needed / General Tech Chat > How to check big/small ends? | |||||||
Site Admin 6302 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Feb, 2005 at 04:10:16pm
I'm splitting my box/block this weekend (thanks to Tom for the flywheel puller!) - is there a reliable way to check the big/small ends when they're apart, or do i have to strip the block down? |
4th Feb, 2005 at 04:24:23pm
take the crank out and then the rods and pistons and ask morespeed t check them mate
4th Feb, 2005 at 04:32:09pm
that sounds way over my head!
4th Feb, 2005 at 05:24:58pm
Alex,
4th Feb, 2005 at 06:16:06pm
What engine is it ?? because i'm not sure why it needs the small ends doing and how you know this already with out stripping it.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
4th Feb, 2005 at 06:19:56pm
I think you can do one at a time doody? Even so - lifting the mains and big-end caps will reveal if further work will be needed - I hope not!!!
4th Feb, 2005 at 06:27:08pm
I'm never keen on trying to get the blockside mains out with the crank in place, i always find the cam ends a bitch to get back in unless the (Belt) in my case is removed. I do agree though one at a time is the way to go.. and yep it only shows what else needs doing.. I aways replace them if i've got it that far apart because it's not much more work to go the whole hog and rebuild it.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
4th Feb, 2005 at 08:48:43pm
Plastigauge? assuming it looks allright when you whang the caps off. Bugger off, I'm getting there. |
Site Admin ![]() 1921 Posts Member #: 333 Post Whore Tadley, Hampshire |
4th Feb, 2005 at 10:47:07pm
(alex replying from nicky's account)
5th Feb, 2005 at 08:12:04pm
what is wrong with the small ends ? The are interference fit so if there is something wrong it eventually leads to loose pin and scored cyliner walls. |
5th Feb, 2005 at 08:44:32pm
apparently they need replacing - Wolfie? |
5th Feb, 2005 at 11:43:05pm
i bought a 1 owner from new 29k 94 mini sprite with history from new, when i bought it it had a small knock consistant with a small end bearing sound, i had a 1293 motor so i dropped it in the car and sold it and gave the engine to alex thats all the history there is on it Crystal Sound Audio said:
5th Feb, 2005 at 11:48:19pm
Cheers for clearing that up, mate! :)
7th Feb, 2005 at 06:45:30pm
Like I said before there is an interference fit so there are no small end bearings to knock. Most likely the small ends are OK. Minis tend to run noisy, could be tappets, timing gear, big ends, whatever. |
7th Feb, 2005 at 07:15:23pm
EEEEuuurrgghhh!!! That looks nasty!!!
7th Feb, 2005 at 09:10:22pm
and the box?! :( |
7th Feb, 2005 at 09:22:45pm
nah that'll be fine! AlexF |
7th Feb, 2005 at 09:27:25pm
i dont get it.. you joking or being serious?
7th Feb, 2005 at 10:38:56pm
Well I was being serious... I'd always pull the layshaft and mainshaft out if I had a gearbox off an engine anyway for inspection at the very least.
7th Feb, 2005 at 10:48:16pm
What special tools will i need? - the gearbox has only done 2000 miles, but i guess you know better than me about this stuff |
7th Feb, 2005 at 10:54:36pm
28mm and 38mm sockets, circlip pliers.
7th Feb, 2005 at 10:58:06pm
cool :) i dont have a breaker bar, but they're only about ?15..
7th Feb, 2005 at 11:15:28pm
Peterborough isnt too far away from me here in Coventry. I could pop round and go through it with you some time.
8th Feb, 2005 at 07:35:44am
On 07/02/2005 22:54:36 SumpNut said:
28mm and 38mm sockets, Isn't that supposed to be 1 1/2" and 1 1/8" sockets?? And that comes from me who comes from the metric part of the world. I ALWAYS change the little bearing between the 3rd motion hsaft/mainshaft and input shaft. This seems to be even more worn on A+ engines than A ones. The strange thing is that even if the A+ has got a 18mm nose, they are ALWAYS more worn than the 14mm A ones. Could it be budget material spec? Has anyone else got any opinions on this? On 13th Jul, 2012 Ben H said:
8th Feb, 2005 at 09:34:45am
On 07/02/2005 23:15:28 SumpNut said:
Peterborough isnt too far away from me here in Coventry. I could pop round and go through it with you some time. Altho I have never done a diff before.... Hey, that'd be great.. and about the diff, two heads are better than one! I'll get a haynes, and some money, and organise something if thats OK..
