Home > Wanted > Bulkheads wanted
I need a couple of bulkheads. Not the bit that you modify to fit a turbo, but the surround of the speedo hole.
Due to recent regulation changes in racing we're not allowed Weber boxes anymore, so I need to deWeberbox a few cars.
Don't scrap a shell without removing this! :)
All Minis to 96 should be of use.
what about flat sheet? surely this would be cheaper for you?
Indeed, but Minis din't come from the factory like this did they? *wink*
nuukuus
Member #: 6857
Lieto / Finland
Not allowed... It have to look like original is. *oh well*
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Anyone got a picture? Might be a make-able panel.
On 19th Jan, 2010 wil_h said:
Vegard - I have a panel that I can cut out, it won't be for a month or so though. Or if more than one is needed I could send it to Jason to copy?
What size does the panel need to be?
That'd be perfect.
Well, I need one for this:
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I'll have ago.........
Anyone? Not in a hurry yet *wink*
