Home > Help Needed / General Tech Chat > carb problems ?
minimad01
Member #: 8109
Suffolk
i think it is a carb problem i recently fitted an lcd an manifold an ever since my mini has been a bit hard to start its asif its bleeding the hole feul line before it fires up (its turning over like 6 or 7 times b4 it start) anyone shed light on this ??
Drop A Gear An Floor It
Translation:I have a probem with my Mini, I think it is most likely a carb problem. I recently fitted an LCB and inlet manifold, ever since then my mini has been a bit hard to start, it's as if it's bleeding the whole fuel line before it fires up (its turning over around 6 or 7 times before it starts)
Can anyone shed light on this ??
Answer: I think that it is unlikely that the float bowl is emptying meaning it is difficult to start. Have you also change the airfilter?
It may just need richening up. The fuelling requirements will be different with eth new exhaust and inlet, have you changed the carb needle?
Turbo Shed
Member #: 30
Epsom, Surrey
Wil, can you translate your answer? the bit that says "with eth new exhaust"
Come on, there is a difference between one sausage finger mistake and a total lack of grammar, punctuation and sense!
On 18th Jun, 2010 wil_h said:
one finger
Ah, I see you have been on the C Austin speed typing course!!
minimad01
Member #: 8109
Suffolk
sorry for the grammer mistakes, no i havn't changed the needle or the air filter ?
you changed the exhaust manifold, so i would guess leak on the inlet system after the carb ( ie at the inlet/exhaust gasket )
