| Home > Technical Chat > Transmission Losses | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
19th Jun, 2010 at 10:20:17pm
Just wondering what some of you guys are losing through the transmission that are running good horsepower. the rollers i use just give wheel horse power. Not pub talk power! So what would 150 at the wheels likely be at the fly with the usual SC box etc.
19th Jun, 2010 at 10:24:33pm
165/170 at a guess?
20th Jun, 2010 at 06:30:47am
these are from the tm shootout day ,,,
20th Jun, 2010 at 08:49:10am
would be interesting to see what final drive was used against the losses. I know Matt uses a 2.9:1 which might account for the huge loss. Jims too. Does this show that the theory that straight cut boxes give less losses due to less suggested side loadings,is infact bollox? or is this as a result that with more torque, you expect to have larger mechanical losses at the upper end?
20th Jun, 2010 at 09:02:11am
My rear drive car, at the last RR session, was shown to have about the same losses as Sprocket gives for the transverse transmission.Direct drive ( on fourth gear in the 5 speed box),3.7 axle ratio, 6600rpm max.
20th Jun, 2010 at 09:11:45am
I thought the perccentage theory on losses was a bit of an old wives tale ?
20th Jun, 2010 at 09:41:35am
i thought gearbox losses was calculated on rundown, after dipping the clutch at the top of the revs on a pull, making the power output of the engine irrelevant? Yes i moved to the darkside |
20th Jun, 2010 at 10:29:33am
On 20th Jun, 2010 Turbo Phil said:
I thought the perccentage theory on losses was a bit of an old wives tale ? If an engine has a flywheel figure of 100hp & loses 22% in the tansmission, it's lost 22hp right ? If that same engine then makes 200hp it's surely not going to lose 22% again as that would be 44hp lost .... I know the losses may increase a little with more torque going through the transmission, but surely not to that degree ? exactly phil ,the percentages thing is nonsence . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Jun, 2010 at 11:42:53am
Those graphs are very interesting cheers robert, i was thinking it would probably be around the 20-25 mark for losses |
20th Jun, 2010 at 11:57:26am
no probs rr , when i tested my car with a helical box , i got 24 bhp losses ,so about 7bhp more than straight cut ,but remember ,that was on a different rolling road ..but also one that used the coast down method as well. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
122 Posts Member #: 2023 Advanced Member nr Portsmouth ,Hampshire |
20th Jun, 2010 at 07:25:51pm
the run down figure also gets confused with different wheel tyre combinations and tyre pressures so its difficult to compare |
21st Jun, 2010 at 12:01:23am
well genrally i have fund that around 25 hp ish seems to be the norm on a 2.9 diff, any higher then look at tyre pressure and brakes and camber angles
21st Jun, 2010 at 08:24:01am
The logic of the percentage idea is now clearly skewed, so I will avoid the RR operator who gave me that info originally - I continue to live and learn,albeit slowly and imperfectly. |
21st Jun, 2010 at 08:56:41am
When the Don first went on the rollers at Dave Walkers it made 220 engine hp ,this ended up at 178 atw at the time,
21st Jun, 2010 at 08:58:33am
Back in 2002 with the JKD 5 speeder it was 26.5bhp loss. With the KAD dogbox loss was 20.5bhp only. On 5th Sep, 2011 Vegard said:
21st Jun, 2010 at 09:27:19am
power at wheels from the rr shootout .
21st Jun, 2010 at 10:59:38am
On 21st Jun, 2010 fastcarl said:
When the Don first went on the rollers at Dave Walkers it made 220 engine hp ,this ended up at 178 atw at the time, carl 42bhp loss? Sounds a lot for a Mini gbox???? On 5th Sep, 2011 Vegard said:
21st Jun, 2010 at 01:12:21pm
On 21st Jun, 2010 tadge44 said:
The logic of the percentage idea is now clearly skewed, so I will avoid the RR operator who gave me that info originally - I continue to live and learn,albeit slowly and imperfectly. Not all dynos work the same, and there are certain types, that cannot calculate run down losses, and use a percentage figure, one which has been calibrated for that dyno, at some peoples disgust, but, if you were unaware of this, you would find it hard to work out that this type of calculation had been done, as the end figures are still representable, with perhaps a 5% variance, that you would probibly see between dynos anyway. I do agree that a random fixed percentage is a little archaic, and no matter what dyno, you will get skewed results. Does it matter how you get to the final figure as long as that figure is with in reasonable limits and representable of the actual end product? On 26th Oct, 2004 TurboDave16v said:
520 Posts Member #: 2093 Post Whore Grenoble, France |
29th Jun, 2010 at 11:14:13am
I like this site:
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Jun, 2010 at 08:35:36pm
http://home.earthlink.net/~spchurch/church...sting/id12.html On 26th Oct, 2004 TurboDave16v said:
