Home > General Chat > three quick questions... hopefully.. carb and plenum related
retro-racer
Member #: 7907
Thame, Oxfordshire.
ordered a rebuild kit and want to crack on but need to know a few things...
i have a metro turbo carb but it has no throttle assembley on it, now i do have a N/A HIF 44 can i use the throttle assembly from that? i assume it will be ok just want to make sure???
secound i also got a metro plenum chamber but for some reson the brass restrictor ring is missing, does anyone have one or know where i can get one???
thirdley i also dont have the bolts for attaching the plenum chamber to the carb, same as above anyone know where i can get them from or have any they dont need.
Throttle assembly should be fine
I made a new restrictor ring for mine out of a short length of 2" exhaust tube.
The bolts are just UNC (1/4 or 5/16 but can't remember which sat 300 miles from one.
5/16UNC x 3"
http://www.turbominis.co.uk/forums//index....p=vt&tid=310316
retro-racer
Member #: 7907
Thame, Oxfordshire.
cheers guys, one more thing i shall have a go at making my own restrictor ring but you know the square knotch at the bottom what hight is it??
retro-racer
Member #: 7907
Thame, Oxfordshire.
Bump anyone know the dimentions of the restrictor ring??? would be most helpfull as ive never seen one before so dont have anything to go from to make a new one...
