Home > Help Needed / General Tech Chat > Mini Turbo MPG
m_brady15
Member #: 8011
Dear all,
I have a 1992 mini shell and putting a 1293 metro turbo engine into it with around 140bhp.
What sort of mpg would I roughly be able to get on the motorways and long distance driving at around 70 - 80 mph?
I know its hard to say as you need to take lots of things into account but i'm just wanting a rough figure?
Many thanks
Miles
MarkGTT
Member #: 1194
Shropshire.
30 to 40 ish.. on a well set up engine at 70.
Edited by MarkGTT on 24th Jun, 2010.
i would give a figure of around 23 to 26 mpg. if your CR is 8.5:1 ish ......
I can tell you that the van does less then 30mpg with the part throttle lean off connected. However the AFR is between 13:1-14:1 at cruise which IMO is a bit rich.
The van also doesn't have a very high advance curve - as we're home brew tuning at the moment we're airing on the safe side.
The current map has quite a lot of advance *smiley*
but it's not been rolling roaded to get the optimum
MarkGTT
Member #: 1194
Shropshire.
i get over 30 off boost on the motorway with a AFR of about 14:1
but it hardly ever sees a motorway the rest of the time i get about 15 mpg
You can have power, economy and reliablity. Just not all 3.
I worked mine out to be near 40mpg on a 150 mile round trip to Avon and back last year. *happy*
Joys of EFI
tadge44
Member #: 2500
Buckinghamshire
I can get 40mpg as long as I stay below 65 and dont use the boost, but whats the point of that ?
MarkGTT
Member #: 1194
Shropshire.
run that by me again..
i can name a few cars that have all 3.
I meant with a mini
Scruffy
Member #: 328
Seaford Rise, South Australia
When I was running in my KAD on the road back in 1996 it was giving me 40mpg on a run.
On 5th Sep, 2011 Vegard said:
40mpg upwards here too
Nick
Member #: 154
Midlands
i got 42 on the way to newquay the one year, mid 30's day to day and much less when having fun.
41 mpg on the last blast across country to the bath rr day about 70 odd miles .not taking it easy ,but not thrashing .
Jay#2
Member #: 648
Northern Ireland (ex AUS)
26mpg to work and back but very rich on boost and about 12:1 AFR on cruise. If I get over 30 with it all set up I'll be happy!
On 7th Nov, 2008 Nic said:
naeJ
m
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I remember my old standard Metro turbo was near 40mpg. In the 20's driving like a nutnut.
On 19th Jan, 2010 wil_h said:
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
lowest fuell cons was with the first mini turbo, it was a near bog std mety turbo eng with a cooler and 10 psi, coming back from belgium quietly at 50/55 mph,it returned to be a 60 mpg trip... awesome
