| Home > Help Needed / General Tech Chat > Half moon seal....odd one? | |||||||
24th Jun, 2010 at 10:11:07am
Should it be possible to remove this with the engine and box bolted together? Im asking because I replaced my timing backplate gasket the other day, and whilst scraping to old paper gasket off the block, I managed to move the half moon seal and then remove it by hand? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Jun, 2010 at 10:13:24am
It should be slightly compressed as thats what creates the seal. Did you put any silicone on itn when refitting? I seriously doubt it! |
24th Jun, 2010 at 10:21:45am
IIRC, it has 2 or 3 three raised lips around the outer circumference which "fold over" to make the majority of the seal and it is slightly longer than the 1/2 circle so it compresses a bit to seal on its ends.
24th Jun, 2010 at 10:22:32am
Yeah I put some RTV sealant on in(always have done). It was a good push fit to get it back in, but ive seen alot of threads saying you need to split the engine/box to replace it, which made me think something might be wrong?! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Jun, 2010 at 10:30:34am
Im sure it'll be fine I seriously doubt it! |
24th Jun, 2010 at 11:57:04am
Hopefully, otherwise I won't be bringing the mini to Avon! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Jun, 2010 at 12:20:11pm
On 24th Jun, 2010 matty said:
ive seen alot of threads saying you need to split the engine/box to replace it, which made me think something might be wrong?! Have you been spending too much time on TMF recently?
Seriously though, thats what you get told! On 26th Oct, 2004 TurboDave16v said:
24th Jun, 2010 at 12:57:23pm
Lol, I actually did a search on here! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Jun, 2010 at 04:12:02pm
I always chop some length off mine. I didnt last year and it was the first one i had to leak.
24th Jun, 2010 at 04:25:12pm
I chop a bit off mine too as they are usually too long. If something is worth doing, it's worth doing half of. |
24th Jun, 2010 at 05:46:26pm
I've never chopped anything of the end - they appear too long but (IMO) that is how they compress into place. If they were the "right" length there would be no compression on the end faces.
24th Jun, 2010 at 06:12:57pm
On 24th Jun, 2010 Rod S said:
I've never chopped anything of the end - they appear too long but (IMO) that is how they compress into place. If they were the "right" length there would be no compression on the end faces. . yup thats what i do too rod . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Jun, 2010 at 06:17:51pm
Silicone or RTV is just a gap filler in this case, it doesn't adhere to any sort of rubber/nitrile/etc. just fills the gaps on a badly fitted seal. I use silicone but my seal is not badly fitted I seriously doubt it! |
24th Jun, 2010 at 06:32:11pm
On 24th Jun, 2010 paul wiginton said:
I use silicone but my seal is not badly fitted No offence was intended Paul, but if the seal fits right, why use silicone or RTV ??? You wouldn't use it on your brakes, which are a similar lip seal design.... OK, bad example to make a point as brake seals move, rather than being static, but the half moon seal is the same principle if you look at the clever bits around the outside of it. But the use (or mis-use) of silicone/RTV is, as I said, just my personal preference. IMO it's only for metal to metal so the only place I've used it on a Mini is the later diff housing which has no gaskets. Schrödinger's cat - so which one am I ??? |
24th Jun, 2010 at 07:17:42pm
No offence taken, I just silicone everything for the hell of it really I seriously doubt it! |
24th Jun, 2010 at 07:45:28pm
The real problem is that you can no longer get the ridgid backed seals, so RTV helps. If Rover used RTV on this seal at the factory, thats a good enough excuse for me to do the same? It's clearly a belt and braces thing, and that is not such a bad thing. I certainly wouldn't call it miss use. On 26th Oct, 2004 TurboDave16v said:
784 Posts Member #: 912 Post Whore North Yorkshire |
24th Jun, 2010 at 08:18:50pm
Because of this thread my half moon seal has started to leak. Only after 120 running miles.
I drill holes in everything..! |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
24th Jun, 2010 at 08:22:28pm
Same here. I put RTV on every gasket :) If needed or not - I feel better with doing it this way and so far the engine deosnt leak. Not that much anyway [X] nail here for new monitor |
24th Jun, 2010 at 09:40:37pm
i use bathroom silicone ,never had a problem of any sort ,,only requirement is , it must smell of vinegar ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Jun, 2010 at 09:50:07pm
No no, Unipart RTV all the way, it smells of rotten fish! [X] nail here for new monitor |
25th Jun, 2010 at 02:38:25am
I alway reuse the genuine steel half moon with a bit of sealant each side and never had on oil leak at this place. |
25th Jun, 2010 at 06:50:08pm
The rtv im using smells of vinegar too....
25th Jun, 2010 at 08:10:12pm
I am drooling thinking about salt and vinigar crisps too On 26th Oct, 2004 TurboDave16v said:
25th Jun, 2010 at 10:11:37pm
salt and vinegar crisps make my nose sweat... On 20th Oct, 2015 Tom Fenton said:
26th Jun, 2010 at 08:50:38am
