| Home > Help Needed / General Tech Chat > Poor runing - particulaly under half throttle | |||||||
35 Posts Member #: 397 Member |
6th Feb, 2005 at 06:16:44pm
After replacing the head hasket last weekend my 1330 has been running poorly ever since. To start with i thought it was a blowing manifold. So i replaced a couple of studs and replaced the nuts. |
6th Feb, 2005 at 07:31:36pm
Could be a manifold leak on the inlet side. also what did you set the valves to ??
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
6th Feb, 2005 at 07:51:50pm
as in tappets? If so 13 thou on both inlet and exhaust.
6th Feb, 2005 at 07:54:25pm
There are many things that could be causing this, certainly sounds like fueling so a decent rolling road should be able to sort it. I take it its a none turbo?? but have you got the balance pipe fitted on your carb, runs from the flywheel side of carb to the top. If you have it could be worth blocking it off to see if it improves things but personally would book up a rolling road session. -MINI CLUBMAN 1380 TURBO- |
6th Feb, 2005 at 08:01:06pm
it is N/A, in normal circumstances i would go along with it being fueling, but it ran faine ebfore i took the head off, and i haven't altered any of the setting since then? |
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
6th Feb, 2005 at 08:13:39pm
I just rebuilt my motor and the carb was ok before and duff after it only sat for 4 days I tryed cleaning a couple of times then changed it all was ok as soon as I changed the carb.????? |
6th Feb, 2005 at 08:30:57pm
is there oil in the dashpot? |
6th Feb, 2005 at 08:48:50pm
yes definatly oil on the thingy (forgot what its called) when you remove it from the dashpot.
6th Feb, 2005 at 09:36:55pm
good, i had a similar problem once, very very annoying, it turned out that it was low on it, filled it back up and it was fine |
7th Feb, 2005 at 12:19:05am
minie did the same turned out to be the coil probably talking shit though just a thought |
7th Feb, 2005 at 11:33:24am
change the coil! if that checks out ok,
7th Feb, 2005 at 01:53:31pm
Check the mixture by doing a plug chop, see what colour they are that might help diagnose air leaks giving weak mixture.
