Home > Help Needed / General Tech Chat > what pistons would you recommend?
miniboy001
Member #: 8367
bucks
what would be the best pistons for a turbo engine? that will be +40 so is that 1310cc?
thanks ben
Nick
Member #: 154
Midlands
depends on a lot of things...budget, power etc?
cast omega, forged omega, forged acrelite
if money was no object there are cheaper, but you get what you pay for in pistons ( and most things tbh)
I'd go for aluminium pistons , the cast iron type are too heavy in my opinion,
miniboy001
Member #: 8367
bucks
where would be the best place to find the aluminum pistons?
supermotolee
Member #: 2153
kings langley
carl thought you'd have opted for Ti pistons
aluminium pistons?? noo way...
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
if he makes a set if Ti pistons then I'm ordering a set for my 850 lol.
You'll struggle to get anything other than the cast Omegas in +0.040", last time I tried the Accralites were special order only & well overpriced.
A decent cast piston is fine, I'm running the cast Omegas on a minimum of 15psi & have been doing for nearly a year now.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
minispares alloy mega's + 40 are also a good set.
Im running Hypatecs with no issues as of yet! I ran a few stupid boost when i first ran the car too and they survived very well!
I think theyre squeezed cast or summat?
How may psi's this year mike with your new actuator. If your strong enough to fit it that is *wink*
go for the cast omega pistons from MED well proven & good!
the ultimate piston is ACCRALITE forged pistons very well made around £400 ish .......
fab, the minispares mega pistons are good but ................... they will not stand the SLIGHTEST touch of detonation with forced induction as the ring lands break up quickley, for many uses on this forum its ended in tears................ carl runs them in the DON and they have survived but he pays attention to fueling and timing so theres no detonation.
great results in N/A engines though
fab
Member #: 100
Paris' suburb
You're right but I think that when you're modifying your engine
You HAVE to pay attention to fuelling and timing.
put 30 deg timng and 15 psi's on 9/1c or 24° at 15 psi and 14 afr or unlivable whatever you want you'll kiss your pistons
M00any use on this forum show guys that don't know about nothing thinking that they can go thru money, making themselves some shit to not spend a penny !kiss your pistons
Sorry,
