Home > Help Needed / General Tech Chat > confused!!
sausage-man
Member #: 7738
nothern ireland
hello ivegot my engine nearly sorted out and now im starting on my geabox i realy dont no wat to do .hopefully my engine will be biteing the ass of 150bhp id like a gearbox that would withstand this power any advice would be appreciated..thanks
Edited by sausage-man on 29th Jun, 2010.
the gearbox is not the weak link its the drop gears so to speak............ well here goes .........................
if you are sticking with a standard helical gearbox thats fine, but you need to run straight cut drops then it will survive but the ratios are a little short
the second option is change the the ratios in the box for a minspares clubman set and get the ratios of nearly turbo metro challenge set, and then you can use the helical drop gears which would be more quieter than SC drops,
in both instances you need to use a minispares X pin diff outhewise power outputs approacing 130 bhp and over will shred the standard item
or you could use SC drops and the clubman set ............
the choice is yours ?
what ever work you do please renew all with new bearings if you want i can provide this service for you please PM me................... oh! and dont forget to fit a centrall oil pick up pipe in there, a must for the spirited driver
How do the helical drop gears survive with straight cut gear set if they dont with a helical gear set? what has changed?
Im confused *oh well*
Other than me has anyone broke a helical drop?
Nick
Member #: 154
Midlands
anton has in a nat asp 1293.
Edited by Nick on 29th Jun, 2010.
pushing 150? i would be tempted to use straight cut drops, box, and at least a 4pin diff all from minispares
braking the box could lose you the whole engine
Edited by Brett on 29th Jun, 2010.
Hows that?
Robert runs helical drops with a known poor 200lbft torque (remember its torque not power that breaks things) and if you run a full windage tray, you only need turn the engine off the instant you break the box.
How many people have lost the whole engine by breaking the box?
Straight cut gears break too!!
The key to standard bearing type idler gears is to shim them on bottom limit with an assembled engine. Any idler failure without the information of clearance before and after, means nothing IMO
Edited by Sprocket on 29th Jun, 2010.
I was discussing this only the other night. Broken drops used to be a common problem in the past, even on low powered engines (50 to 60bhp).
But in all cases, every failed drop I have seen was on an A series with the smaller bearings. The later A+ larger bearing idler is a lot more resillient, as Robert has shown.
sprocket, by desighn the helical drops are stronger ......but its the twisting motion which starts from the primary through the idler to the first motion shaft and then on to the worn out bearing in the first motion shaft
which inturn places massive load on third gear and strips the third gear and the third gear head set,
because we ave a SC headset and third gear, the gears are unafected as theres plenty of room for them to move especially .....the new bearing helps !
i think robert on here has run for a few years 197 bhp and shed loads of torque with out any problems
hope this helps, we can now have a quite motor and the right gear ratios spending your money in just the right area
Anton
Member #: 764
Staffordshire
As nick said i mullered a set of helicals with abouth 70-80lb/f they were of the a+ variety.
Isnt roberts seperatly oil fed?
Out of interest, if helical drops fail, where do they fail ???
Is it the teeth shearing off, or a failure of the shaft/bearing/thrust washers (especially as the pre-A plus is a smaller shaft).
In my experience it's the idler bearings that fail leading to total failure
Anton
Member #: 764
Staffordshire
Yup thats what happened with mine.
I also belive the life of them could be down to the drivers style of driving... i.e. no mechanical sympathy.
Thanks both, I was hoping that would be the answer. (I've never seen a failed one yet....)
I am trialling this setup on my clubby. Idler tolerance was at bottom limit upon installation (used new idler bearings and a freshly built SC/BOX)
This will be in the car until around december and should see a couple of drag events and undoubtably some spirited road miles and perhaps some of it mechanically unsympathetic.
I plan on stripping for inspection at this time and if there is evidence of wear or damage they will be replaced with some 1:1 SC drops.
What do you mean perhaps? I'll be driving it some of the time!
That was why I said it.
