Home > Help Needed / General Tech Chat > gearbox noise - any ideas???
jimmyjonga
Member #: 8947
macclesfield cheshire...
hi there
my gearbox is making strange noises, i want to see if anyone has any ideas, that may mean I dont have to take the box out to look to see whats wrong.
the noise sound like a tapping noise, when in neutral, that sounds a bit like a big end knock, but disappears completely when the clutch pedal is pressed. I was thinking maybe a gear has a broken tooth?? dont really know....
I know i am going to have to remove the box, but thought someone may have a magic easy answer!!!
james
Turbo Shed
Member #: 30
Epsom, Surrey
clutch bearing?
kenny2
Member #: 5362
wexford in ireland
mine is making the same gets worse with revs??
On 5th Jan, 2011 wolfie said:
It'll be drop gear related most likely. Sounds like maybe excessive end float in the primary or idler, could also be a failing nose bearing.
Needs investigation befor it self destructs IMO.
Just wind up the ignition advance a tad and it will go away.
jimmyjonga
Member #: 8947
when you get your head under the car it sounds like it is coming straight from the middle of the sump, i will get the box out over the weekend if i get the time.
alpa
Member #: 2093
Grenoble, France
I've got the same.
Changed bearings, adjusted idler end float, changed clutch and clutch bearing: noise is still here.
I think it's the clutch bearing, I've got exactly the same noise on the Maserati biturbo known to have this "problem".
Anton
Member #: 764
Staffordshire
Is there any whine from the gears (assuming a helical box)
Mine was similar noise with a faint whine, not long afterwards the idler bearings shat themselfs.
check your exhaust isnt touching the body, this can make misleading noises.....
