Home > General Chat > How light can you go
spanner1981
Member #: 8970
shropshire
hi was just wondering how light members have gone (kerb weight) as i no starndard mini saloons weight is 1406lbs with manual trans
as i need to kick as much weight out as possible as i am sticking a bike engine in the front and staying front wheel drive
i have fibreglass front, doors, boot,seats,polycarbonate windows,custom front subframe i am currently trying to make a beamaxle any ideas thanks
theres a guy o here called david essex he'l tell you the way to go light.....
i managed 670kg in my pickup iirc
spanner1981
Member #: 8970
shropshire
cool was trying to get it to at least 800lbs be happy at that be same weight as kitcar so was hoping for same sort of performance thanks
On 8th Jul, 2010 spanner1981 said:
as i need to kick as much weight out as possible ............... any ideas thanks
There is no one magic weight saving trick, instead go though everything & I mean everything and ask you self, firstly is in needed, and if it is how can you make it lighter.
That twat dont know what the fuck he's on about
Cant see you getting it to 800lb tbh
Edited by paul wiginton on 8th Jul, 2010.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I agree. That's a shade over half of factory weight!
On 30th Apr, 2010 Rod S said:
Gary's description is best
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Holes are your friend....
363kg = 800lb, that would be bloody good going, the DON is about 440kg without the cage in.
jamz
Member #: 2292
Tool
Herne Bay, kent
363 is pretty immposibble. im going light on evrything andhaving nothing in the car at all tht isnt used and im aiming for 599kg bassically anthing starting with a 5. this is possible i hope
cant beat a good blowout.
The lightest car Ive heard of was 395kg which was Carls Twinny before it was a twinny. Lots of clever engineering went into it to get to that weight.
If a bike engine is lighter than A series then you could come close to 400kg(ish)
but lets face it any mini lower than 600kg is fun...
Oli
Member #: 1910
Wilts
but surley its going to come to a point where the cars going to so light and not be able to get good traction etc....
firberglass or a cf shell, but still will end up weighing 400kg's probably. even space frames arent that light.
if its only for drag racing could always do a shorty splint shit handeling but could work
jamz
Member #: 2292
Tool
Herne Bay, kent
yer that is true. id be happy 10kg either side o 600
spanner1981
Member #: 8970
shropshire
cheers for all that input i was trying to work out weight difference in engine weight saved mite try atkins diet see how that go's
what changing to a bike engine saves half the cars weight?
spanner1981
Member #: 8970
shropshire
nar but what does a standard 1275 engine weigh i dont no answer but id say bike engine is half the weight of that
use the search mate you will find alot, subframe lightening, pic's of paul w's car the don Nic's and mattys car oh and check ian_w's car as well all had quite alot of weight taken off them.
spanner1981
Member #: 8970
shropshire
cheers thanks will do
Asphalt
Member #: 1027
Germini, black forrest
About 150kg. Not that heavy...
[X] nail here for new monitor
