Home > Technical Chat > counting cogs
Dangerous
Member #: 417
I have a metro challange box and diff,but want to check it before it goes together.
Does anybody know how many teeth I should have and where??*blush*
Also No off teeth on diffs for 2.9/3.1 etc
Thanks Brian
No idea on teeth numbers. But diff ones easy to work out, mark crownwheel with a dab of paint and then count the teeth by turning it, then do same with pinion, then divide the two and you have the answer.
Do crownwheel first as otherwise dab of paint would get everywhere and confuse your counting......
mikes minis
Member #: 421
nr newark lincolnshire
18/62 = 3.44
19/59 = 3.1
20/59 = 2.95
What teath do you have on the laygear, I have 14, 18, 22, 23
that is from a challenge box
Dangerous
Member #: 417
15,19,23,25 from a so say challange box ??
Thats the shaft at the front of the gearbox
Edited by Dangerous on 10th Feb, 2005.
Dangerous
Member #: 417
oh and 20 on the diff= 2.95
any good on 10" wheels ??
doesn't sound like a challenge box to me then, I'm sure my boxes are, as I have talked to Jack Knight and counted the teeth while on the phone to them.
Where did you get the box from?
Does anyone know the teeth count on the lay gear of a normal sc cr syncro box?
as regaards to diff, all depends what you want todo with your mini, matt woods uses a 2.9, but there crap for drag racing
Dangerous
Member #: 417
It was "roversport"
in my vizard book I have
24 21 17 13//25 22 18 13//23 20 17/13
Nothing the same as mine :$ :$
are the gears stamped with JKD? as they made them for rover sport
dan
Member #: 93
on my jkd dogbox the laygear is 14,18,21,23
and mainshaft 31,27,24,22 giving
the 'challenge' ratios of 2.315,1.568,1.195,1.000
Edited by dan on 11th Feb, 2005.
Dangerous
Member #: 417
Found some more figures
The ratios shoulds be:
2.31 1.57 1.19 1.00
Now this is similar to the Jack Knight set:
2.31 1.56 1.19 1.00
the setup for that is:
1st - 31/14 - 2.31
2nd - 27/18 - 1.56
3rd - 24/21 - 1.19
4th - 22/23 - 1.000
so thats a 14-18-21-23 laygear..
I just re counted mine, I can't count they are indeed 14,18,21,23
Dangerous
Member #: 417
Right counted the lot
Layshaft 15.19.23.25
Other shaft in order 29.(33).25.22.19 dunno what the 33 cog is
Which one do I divide by which as I think some of the maths above is suspect
Edited by Dangerous on 16th Apr, 2005.
I've sold my spare gear kit, so I can't count any more, sorry
i can though *wink*
i will try to later for you. its got plenty of pen marks on it where jims counted it before!!
Dangerous
Member #: 417
just been playing with this
http://www.quaife.co.uk/info/calculator.htm
Do mini box have a dropratio from first motion shaft to layshaft i.e 19:25 in my case
I then calculate
1st 2.5:1
2nd 1.7:1
3rd 1.2:1
4th 1:1
Right then,
The ‘33’ is the idler for the reverse.
So, lets work out the headset ratio:
Hence 25/19 = 1.31
Now work out the intermediate ratios:
1st: 15/29 = 1.93
2nd 19/25 = 1.3
3rd: 23/22 = 0.95
Now multiply by the headset:
1st: 1.93*1.31 = 2.53
2nd: 1.3*1.31 = 1.703
3rd : 0.95*1.31 = 1.24
4th: 1:1
Edited by turbodave16v on 18th Apr, 2005.
