| Home > Technical Chat > Blow through charger part throttle issues | |||||||
301 Posts Member #: 2480 Senior Member Swindon |
10th Jul, 2010 at 04:38:45pm
Hi all. Im doing a blow through charger and having issues with it on part throttle. Its got standard rockers fitted now rather than the 1:5's it did have and a 286 cam i think off the top of my head. Also fitted is the bini bypass valve. It idles fine but if you try and drive it on part throttle the valve takes too long to close. We have also fitted a dump valve to help and it has but its still not right. Its running at 1.2bar at the mo. Maybe a weaker spring? Another bypass valve? Can anyone advise? Many thanks guys feature=mhum |
10th Jul, 2010 at 08:35:27pm
Might help if you gave more details on the setup, and the actual problem.
10th Jul, 2010 at 09:04:57pm
well. The valve sits between the ic and the plenum. When you take your foot off the pedal, the valve is sticking. You can clear it by bliping the throttle and from full throttle to coming off it works fine. Its at part throttle/cruise where the problem is mainly feature=mhum |
10th Jul, 2010 at 10:46:47pm
sticking open ? sticking closed ? what opens and closes it ? what sort of design is it ?
10th Jul, 2010 at 10:49:39pm
Further confusion too.
Edited by stevieturbo on 10th Jul, 2010. 9.85 @ 145mph
11th Jul, 2010 at 12:15:31am
No those pics are of the old vmax setup. The valve is the one used on the bini and closes when the throttle is applied and opens to vent the boost out when off throttle. It is mechanical and acts much the same as a dump valve. It has a butterfly and vacum pipe and sits inline just before the plenum. Its trying to stay close when you come off the throttle and you have to blip it to get it to open proper feature=mhum |
15th Jul, 2010 at 08:37:50am
All sorted now. Next stop MOT! feature=mhum |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
15th Jul, 2010 at 11:22:29am
what was the issue Jonny? Sticking valve? Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
20th Jul, 2010 at 07:36:49pm
not to sure. We have relocated it and seems to have cured it!? Taking it for its MOT tomorrow and hope to have it home on the weekend! feature=mhum |
