Home > General Chat > Harness Attachment?
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Hey All,
Just wondering how everyone has attached their harnesses(5 point and otherwise)? Especially people not using a roll cage.
-James
standard rear mounts for me but i have seen alot using the weld in squares with the captive nut
Edited by Brett on 12th Jul, 2010.
miniswordsman
Member #: 6558
Where be they welding them in?
to the rear bulk head, i know Nick has done it this way have a look in his build thread,
nutter driver
Member #: 47
Not very sunny swanage
to be totally honest, i wouldnt even consider using harnesses without at least a rear cage to mount them off. The rear bulkhead just isnt designed to take the stresses of seatbelt mountings in the propper orientation, (ie nearly horizontal, NOT down to the base of the seat)
not having a go, just my 2p
miniswordsman
Member #: 6558
I appreciate you're input Nutter, and I know its not. I intend to be putting a cage in it next year, but I need to get it on the road this year as I have a kid on the way and I know the missus will try to put a kabosh on doing anything to the car once the baby is here.
Simon
Member #: 1865
Norwich, Norfolk
the rear straps should be between 0 degrees (horizontal) and 45 degrees downwards.
i have been told that mounting the weld in plate on the back of the rear seat should be fine as it has a lot more strength in it than the rear parcelshelf.
have i been told wrong?
If you bolt them to the bottom of the rear seat back, this is only OK if the car has already got harness anchors. 80ies cars have if I'm not mistaken.
I made a bolt in harness bar that spans between the rear arches, three M12 bolts either side, and then bolts to the center of the rear seat back/ bulkhead with another 2 M12 bolts. Much better positioning of the shoulder straps
miniswordsman
Member #: 6558
That's a good idea sprocket, do you hav any pics?
Ben H
Member #: 184
Melton Mowbray, Pie Country
On both the race cars we have a large plated welded to the back seat and then 2 of the captured nut plates welded to that. I appreciate that people think it is not that strong, but we have had quite a thump in it and it didn't deform.
Attached to a cage is better, but if you weld in the parcel shelf properly it makes a good strong box, imo.
http://www.twin-turbo.co.uk
miniswordsman
Member #: 6558
You know, I think I need to look at my mini again, I may be mistaken, but I think someone did exactly as you've described to my car, Ben...
jpboost
Member #: 29
Croydon
For Info...
I just checked the installation instructions on my harnesses (LUKE) and they say that any mounting point used should be rated at 2000kg...
My mounting points are strong (mostly on the cage), but 2000kg is quite a loading!!
Too many projects!
whats the load capability of an 8.8 7/16 unf bolt?
spanner1981
Member #: 8970
shropshire
on my old mini that i wrote off i drilled rear seat bulkhead and sandwich plate and the seat mounting broke shitty cobra frames welds not good at all the belt mounts was spot on i reckon saved me
Quick and dirty, just over 10T, this is for a grade 8 (6-line) steel bolt, as imperial threads are not rated in 8.8 etc as metric stuff is.
Tom, I can show you a grade 8.8 bolt with an imperial thread. They were the harness anchor bolts that came with Sparco bolt in E aproved four point clubman harness
8.8 is roughly grade 5, and we don't like using them in our engines, so why use them on something that might save your life. That was my thoughts anyways*oh well*
Edited by Sprocket on 13th Jul, 2010.
