| Home > Help Needed / General Tech Chat > What's left..? | |||||||
275 Posts Member #: 4600 Senior Member Melton Mowbray, <BR>near Leicester |
16th Jul, 2010 at 09:22:48pm
Since deciding to learn about turboing, and actually turbo my engine about a month ago I've spent a fair amount!
16th Jul, 2010 at 10:00:25pm
the tank will be suitable yes, but dont run silly boost! im not too sure what you can run with these tanks but i ran 10psi without fueling problems.
16th Jul, 2010 at 10:10:57pm
cheers, ill get a bid in on it
16th Jul, 2010 at 10:22:32pm
Iirc the standard SPI pump puts out about 15psi or so, so 10psi of boost is about the max you can run on one of these tanks.
16th Jul, 2010 at 10:29:52pm
Well I'm only running a T2 on a 998, with fairly standard innards, so I won't be running a high boost |
16th Jul, 2010 at 10:43:02pm
You can always change the pump at a later date. Im running a Ford puma pump in my spi tank. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Jul, 2010 at 08:47:20am
yep, the in tank pumps all seem to be of a similar design, something from a ford or honda will definatly fit, just make sure its for a multipoint injection engine and it'll be fine :) On 28th Aug, 2011 Kean said:
