Home > General Chat > lighter metals for subframes
spanner1981
Member #: 8970
shropshire
was just wondering if anyone has used other metals for subframes instead of mild steel or stainless . has anyone try chromo as i no its very light and very strong but expensive is the downside as i see that most members make these items and wondered whats being use thanks
there have been a few instances,
for the rear the is the available beams made from box section, and Fastcarl does titianium ones,
for the front, there is less choice, Z cars sell a frame, farst carl does a titanium one, a couple of people have made their own, paul wiginton springs to mind,
with all the ones mentioned above you need to run coilovers, there was a chap that made a rear subframe from tube bird cage style, i belive that took cones. think his user name was ministef
MikeRace recently rebuilt one using mild steel tube, I plan to copy that
spanner1981
Member #: 8970
shropshire
titanium ffs got to cost ££££££ so not sure about the chromo den
not cheap, light though!
the bare ti front frame weighs about 7kg
spanner1981
Member #: 8970
shropshire
that light as
On 18th Jul, 2010 spanner1981 said:
that light as
That is light!!,
you know i still haven't looked at mikes subframe:$
madcatminis
Member #: 5327
Dudley, West mids
How about aluminium tube and box section?
Not a godd idea if you were to weld it all together as the heat would annea the job making it vsry soft,
unless you used the correct rod and had the lot re heat treated on completion,
alternatively make one up useing folded sheet and rivet/bond the lot together, but you need a fair overlap of area to make this method work succesfully,
Chromo is no lighter than your average mild steel per cm3, it's just as its stronger you can use thinner wall, for best results you would need to fully purge weld it and then it starts to cost in time and gas,
carl
carl
spanner1981
Member #: 8970
shropshire
Fastcarl does titianium ones how ????
Huh?
What is this, a cryptic crossword?
Yes Carl makes Titanium subframes. But other than that I haven't a clue what you are trying to ask.
Please take a few seconds extra to make your posts a bit more meaningful.
spanner1981
Member #: 8970
shropshire
sorry i mean that titianium isnt well i wouldnt of thought it was the easy thing to work with can you weld it ie tig or mig just wondered really how
you can work with any material, you just have to have the knowledge and knowhow, both of which are not easily comeby,
yes it can be welded by tig,
spanner1981
Member #: 8970
shropshire
yeah can imagine how may bad ones did you make till you was happy
none, there's no making mistakes with expensive materials
spanner1981
Member #: 8970
shropshire
was looking at you link fastcarl very nice work mate mite invest in a few bits do the top and bottom arms fit standard subframe fitments
yes.
carl
