| Home > General Chat > Sick of buying shite... | |||||||
18th Jul, 2010 at 04:38:00pm
Got some adjustable rear camber brackets as my cars standard brackets are giving the car posiative camber.. anyway got some from north west minis and they are wank the holes dont line up and they dont feel very strong.. I put the old ones back on and they fit first time.
18th Jul, 2010 at 04:42:16pm
You must know by now you get what you pay for, you payed cheap you got cheap [ read shite china ] as you say,
18th Jul, 2010 at 04:45:21pm
apparently the KAD ones are the best of the bunch, then minispares.
18th Jul, 2010 at 04:48:07pm
I quite like the minisport ones, (a rip of of the KAD ones) but they seem to need fettling too. On 28th Aug, 2011 Kean said:
18th Jul, 2010 at 04:52:47pm
I agree Carl.
18th Jul, 2010 at 05:14:46pm
From your post do you do them? I have looked at your website but I cant find them? I run a supercharger and I don't care the TB is on the wrong side.
18th Jul, 2010 at 05:15:32pm
or can you mod mine? so they are adjustable? at least I would know they will fit. I run a supercharger and I don't care the TB is on the wrong side.
288 Posts Member #: 6267 Senior Member Bristol |
18th Jul, 2010 at 05:48:10pm
I've got the Minispares ones and I thought exactly the same. They don't fit and even when I had spent hours making the holes line up it is almost impossible to get the bolts in even with the radius arm at the limit of adjustment. I'm not sure I want to put them back on my car as they are so difficult to fit. The KAD ones look good but they don't hold the camber adjustment while you adjust the toe. |
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
18th Jul, 2010 at 06:45:37pm
ive got huddersfield ones and there shite, there camber only and theyve made the rear toe out loads and cant get any camber, they read 0 on a camber guage. just saving up for kad one myself On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
18th Jul, 2010 at 06:59:29pm
I have the kad ones and they needed fettling (not much mind) to get the holes to line up. on a gen subframe looks like they all the same.
18th Jul, 2010 at 08:40:46pm
KAD ones look VERy beefy amd would be my choice. Minispares ones are too "cheap". MiniSport ones looks rather OK, but I'd still buy the KAD ones. On 13th Jul, 2012 Ben H said:
603 Posts Member #: 1938 Post Whore near Dundee |
18th Jul, 2010 at 09:00:28pm
ah im glad this has been posted as i los the plot trying to fit the minispares ones recently i gave up in the end |
18th Jul, 2010 at 09:17:25pm
the minisport version on the web site looks like the same material as the ones I have... and I dont want to risk it again. Looks like KAD is the way to go. I run a supercharger and I don't care the TB is on the wrong side.
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
18th Jul, 2010 at 11:30:39pm
minispares ones i had no problem fitting i guess its luck of the draw with what the bloke at the factory is drilling |
19th Jul, 2010 at 01:08:05am
This is not a new problem. I bought a set of the minispares ones back in 1998 and the holes needed elongating. Why the fuck, 12 years on are we still having the same problems!!!! On 26th Oct, 2004 TurboDave16v said:
19th Jul, 2010 at 07:56:37am
Every pair of Minispares ones I have fitted have required trimming - the KAD ones are a pain to set as they have no bolts to guide the toe/camber - must be time for someone to make a set based on both designs On 5th Sep, 2011 Vegard said:
