Home > Help Needed / General Tech Chat > cv joint
m4dn35s
Member #: 243
Portsmouth
Im currently rebuilding the front subframe and are changing the mini disks to metro turbo disks and drive flange but using the mini hub. The problem is i need to change the rubber boot nearest the hub but cant get the cv joint at the further end off so i can slide the boot off! Any ideas how i can do this? iv used lots of force and a large hammer but to no avail *frown*
Cheers matt
Edited by m4dn35s on 10th Feb, 2005.
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
Nick
Member #: 154
Midlands
hold the outer CV with one hand, put lump hammer in other hand and give it a fucking big smack and it'll pop off.
AllanMcD
Member #: 414
Dalbeattie Scotland
That answer dont sound right but I can assure you it is just give it a clout.
http://www.rabdunn.co.uk/
m4dn35s
Member #: 243
Portsmouth
So i clout the cv joint i wanna get off? and basically hold onto the cv joint at the hub end to keep it still?
Will it break the cv joint? this is what i was worried about didnt want to hit it too hard incase it broke lol.
Cheers matt
Nick
Member #: 154
Midlands
yup thats it. the only reason i said hold it is to keep it straight with the driveshaft for ease and so it doesn't pop off and hit you in the nuts
Star Mag
Member #: 375
Leicestershire
IF IN DOUBT GIVE IT A CLOUT!!
m4d
give it some, a short sharp smack
i fitted metro vented discs and hubs these are fine
i used pre 1983 ball joints as they have the same taper as the mini, metro track rod ends as the thread is longer and got a braded brake pipe kit with banjo unions from minispares
oh one thing when you fit these it alters the camber to 1 deg positive so i fitted 1:5 neg arms which brings me to 1/2 deg neg
Star Mag
Member #: 375
Leicestershire
Do ya find you scrubb off tires using this setup my yokos didnt last long at all with a similar setup, lookin at changin mine recently got pictures of how to modify metro vented discs to fit under tens with the metro calippers.
just a touch on 1/2 neg but nothing i cant live with
i have fitted some rose jointed arms over the winter so will be setting these to suit
b16_b
Member #: 429
newcastle upon tyne
minimark is this wot we tried and broke the tool- which i still need to buy a replacement*oh well*!(sledge hammer?:cool: )
Everyone's said to 'twat it', but the easiest (only?) way is to snip the cable tie on the inner pot joint, then remove the whole shaft and outer cv from the car. You then hold the shaft vertically, and tonk the cv towards the floor.
When tonking, hold the cv such that you won't hit the inner ball guide. This is easilly damaged and not easilly replaced.
Edited by turbodave16v on 11th Feb, 2005.
Also - it goes without saying wipe grit / dust / mud / etc off your hammer before using it - or the impact will see this crud headign straight into the cv joint. Which negates the point of fitting a new boot in the first place...
m4dn35s
Member #: 243
Portsmouth
Cheers for ya help i got it off today and have changed the boot and put the mini hub back on.
One more question can i use the mini drive flange with the metro turbo disks i noticed i will have to open up the drive flange securing bolt holes in the mini flange cos they're not big enough but is this all i would have to do? Or is there a reason why the metro drive flanges are kept?
Cheers matt
Nick
Member #: 154
Midlands
i think you've gotta use the metro ones dude, pretty sure they're not interchangeable as the metro one is wider.
Use the metro drive flanges and screws with the metro discs. The mini ones are wrong as you have found out. Think of the consequences of those screws breaking and there is your reason to do it right!!
You will need to get rid of the 4 "lugs" that locate the metro wheel. If you have access to a lathe the best way to do it is to hacksaw off the majority of the lug then machine them up flat in the lathe.
Also you will need to use ERA Turbo caliper bolts in order to correctly locate the metro 4 pot calipers. Do a search as I have explained the reasons why before now and can't be bothered to type it all in again!!! They are available from Somerford Minis, some other places may also stock them too.
SumpNut
Member #: 28
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3443
m4dn35s
Member #: 243
Portsmouth
Cheers sumpnut and Tom, i realised that today and managed to machine the lugs off of the metro drive flange using the mill at work.
Didnt realise i had to change the studs to metro ones does this really need to be done?
Cheers for all you're help im getting there slowly and picking things up.
You need to change the 2 bolts each side that hold the caliper to the hub.
Yes you REALLY need to change them for "ERA TURBO CALIPER BOLTS"
m4dn35s
Member #: 243
Portsmouth
Yer i realise i have to change those. I meant the wheel studs i didnt realise they were removable.
Cheers matt
SumpNut
Member #: 28
The metro wheel studs are the wrong thread, tap them out with a hammer and put mini ones in there
