Home > Help Needed / General Tech Chat > T2 gaskets?????
Kean
Member #: 341
aka T2clubby
South Staffs
Anyone know where I can get the steel gaskets to go between my T2 and manifold and between the exhaust elbow as well?
Ian, can you get these?
ta
I dont use them my self mate, my exhaust doesn't blow. the adapter plates are laser cut, so have not warped and are perfectly flat, just clean up faces with wet n dry on a block or simular
Kean
Member #: 341
aka T2clubby
South Staffs
Cool, im not using the adaptors mate, I've got a mirage setup... hopefully the surfaces should mate well enough, just want to make sure....
you should be ok with one, but you can still buy them
dan
Member #: 93
bbtuning sell them along with new studs etc if you need them, find the site and access the section for r5 gtt
Or at a guess a Renault dealer should be able to supply you?
