| Home > Help Needed / General Tech Chat > Weird clutch problems... [sorted] | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
20th Jul, 2010 at 09:04:28pm
Hi!
Edited by Asphalt on 26th Jul, 2010. [X] nail here for new monitor |
20th Jul, 2010 at 10:31:05pm
The squealing noise can be caused by the more modern asbestos free clutch linings, don't worry too much about it.
72 Posts Member #: 6792 Advanced Member |
21st Jul, 2010 at 09:03:18am
Sounds like the Diaphram doesn't have enough Presure, which there could be a number of reasons for it. |
21st Jul, 2010 at 09:34:07am
21st Jul, 2010 at 09:51:28am
I have not touched them, they are as they left the factory. :) So no new clutch plate and the dowels are all properly located.
21st Jul, 2010 at 10:59:33am
i would put the clutch slip down to the 998 clutch on a (hot -ish) 1275, the 998 spring on the verto is weaker
Yes i moved to the darkside |
21st Jul, 2010 at 11:17:29am
I have never heard a fibre based friction plate screech. what may habe been making the noise is the thrust sleave (top hat thingy) grinding on the clutch spring, or, the thrust sleave grinding on the release bearing because of a siezed release bearing.
Edited by Sprocket on 21st Jul, 2010. On 26th Oct, 2004 TurboDave16v said:
21st Jul, 2010 at 11:33:02am
Colin, i think hes talking about the wok
On 21st Jul, 2010 Asphalt said:
I have not touched them, they are as they left the factory. :) So no new clutch plate and the dowels are all properly located. Yes i moved to the darkside |
21st Jul, 2010 at 11:47:26am
Yes, sorry... Clutch cover = wok (where the plunger & arm are attached too) in my terms. :) This thing: http://img516.imageshack.us/img516/1627/kupplungsdeckel.jpg This was under tension when I removed it which is not quite normal...
21st Jul, 2010 at 01:19:16pm
A right. If the wok is unter spring tension, one of two things are happening. The plunger is siezed in the housing or the slave cylinder has not fully retracted. Or the clutch has not been assembled correctly, thats three, lol. either way, there should be no spring tension on the wok with or without the slave cylinder fitted.
21st Jul, 2010 at 02:25:20pm
On 21st Jul, 2010 Sprocket said:
A right. If the wok is unter spring tension, one of two things are happening. The plunger is siezed in the housing or the slave cylinder has not fully retracted. Or the clutch has not been assembled correctly, thats three, lol. either way, there should be no spring tension on the wok with or without the slave cylinder fitted. Hmm - unless it's been assembled wrong in the factory I can't see how this might have happend. Also it was fully seated on the crank, all like it should be. The plunger moves smooth and easy (was my first suspicion). On 21st Jul, 2010 Sprocket said:
Are the two different top hats the same hight? I cannot remember. The top hats have the absolutely same height, as do all the release bearings I have here. The only difference is, that the 998 clutch assembly is 3mm taller than the SPI's. But that can't be enough to cause such problems!? On 21st Jul, 2010 Sprocket said:
The big plunger nut should be adjusted to give a 6-7mm clearance to the wok when the thrust bearing is up against the top hat (assembled engine) There are also a couple of different release bearings for the Verto. You are using a Verto release bearing? The nuts were adjusted about right; but if the clearance was too smal, this would surely only give trouble with a not fully disengaging clutch if you press the peddal? I can't (yet) see the relation to that problem here tbh? :) The problem I have is a partialy disengaged(?) clutch when NOT pressing the pedal. Yes, I use a Verto bearing (the one with the 'clamps', attached with a rubber ring). This one: http://minispares.com/Product.aspx?ty=pb&pid=35421 On 21st Jul, 2010 Sprocket said:
There should be no need for lube as the top hat will spin with the flywheel and clutch with the release bearing allowing the rotation Ok. I'll use the tighter fitting top head, just for peace of mind :) Hmmmm - could there be a connection with too much primary gear play? [X] nail here for new monitor |
21st Jul, 2010 at 04:05:45pm
an ill fitting primary gear will cause oil leakage. On 26th Oct, 2004 TurboDave16v said:
21st Jul, 2010 at 06:04:33pm
Ok, but no squeal due to runing of square on a semi-released clutch or something like that?
22nd Jul, 2010 at 08:09:57am
yes, my injection flywheel is lighter by almost a half a kg to, its from the groove the reluctor ring sits in on the reverse side of the flywheel, Yes i moved to the darkside |
26th Jul, 2010 at 05:38:46pm
Sorted. SPI clutch, Turbo clutch plate and SPI flywheel. And I used the top hat with the plastic bit.
I would guess it maybe produces 80lb/ft?
