Home > Technical Chat > CR... Bugger
advantage998
Member #: 1840
Kings Lynn, Norfolk
Well these are my calculations:
1293 / 4 = 323.25cc
head chamber = 20.5cc
head gasket = 3.8cc
piston dish inc cutouts = 11.5cc
deck volume and ringland = 1.5cc ?? pure guess
323.25 + 37.3 / 37.3 = 9.66:1
Deck and ringland if not too sure on, the pistons are 15 thou below the deck and they are omega cast 10cc dish.
Am i right in thinking 9.66:1 isn't realy suited to a 20psi charged k100 engine? I was planning a max of 9:1, but the block needed a bigger skim than planned.
just the deck height at 15 thou will be 1.5cc, you can prbably call it 2cc min for deck and ring land, still only gets you to about 9.4 though,
best option is to take the dishes put bigger, if you can find 4.5cc in the piston you are at 8.7 which should easily be ok on the K head on 20 psi
I needed to use 18cc pistons to get a k1100 head dowm to around 9:1 with zero deck hight and 18.5cc chambers
Ring land volume is usualy around 0.5cc, and gasket volume will depend on the type of gasket
Mine works out to be 9.1:1 using 15cc pistons + 2cc for the valve cut outs. *oh well*
advantage998
Member #: 1840
Kings Lynn, Norfolk
Thanks for the help guys i will see what i can do on the lathe to get a bit more dish in the pistons.
