Home > Help Needed / General Tech Chat > mpi crank trigger wheel help
ashley_dude00
Member #: 1751
chichester/bognor
after a trigger wheel that will go on to the mpi crank pulley.
any help would be greatful looked around lots of the posts and searched,loads for non mpi.
i have messaged mr fenton as well to see if he does one so i may have answered my own question
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. *wink* iam on pretty much every day as i lead a sad existance
Flame Red
Member #: 6267
I can't see any reason why this wouldn't work
If you look at the fitting guide they put it on an MPI
http://trigger-wheels.com/store/contents/en-uk/d30.html
A simple search for MPi Pulley brought this back in the results
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=315574
I bought the trigger wheel from some one on here, but I know some one who has used one of the trigger wheels .com ones. You just have to choose which size is suitable. You then machine the pulley such that the trigger wheel is a nice fit but loose enough to rotate. Only machine the pulley down a little less than the thickness of the trigger wheel, so that when you drill and tap the pulley for M5 screws, the screws clamp the trigger wheel onto the pulley before the screws bottom out on the pulley itself.
ashley_dude00
Member #: 1751
chichester/bognor
thankyou sprocket,was just wondering if you had any trouble of the damper moving and moving timing out at all.
