Home > 998cc > 12g202
pieter
Member #: 7577
belgium
yesterday i got a 12g202 head in good nick off a friend of mine.
it is unskimmed and i would like to use it for a project.
I would like to install it on a na 1.0l innocenti engine with powermax pistons
as you can see the exhaust ports on both heads are the same
the only difference is the inlet port and total chamber size
12G202
1 5/32"
29,53mm
1"
25.4mm
26,1cc
12G295
1 7/32"
30.95mm
1"
25.4mm
28,3cc
does anyone have any experience with this?
and will 12g295 valves fit on the 12g202 head when i adjust the inlet ports?
In Short! ................
the 295 head is the one what has nearly! all the work done for you in the factory casting but needs a little more port work etc.... to make a superb head.
the 202 head is simlar but does not have as much work compleated in the factory casting process but....... it can make a storming great head with a little extra work! *smiley*
the inlet valves wont interchange without machining new seats for the extra valve size you are after .... but thats not it,
you need to alter the combustion chamber to remove the extra material around the valve which is shrouding the oversized valve you plan to fit inorder so it flows correctley and takes advantage of that larger valve
you may need to skim the head also to get the desired CR you are after ?
hope this helps
pieter
Member #: 7577
belgium
thanks for the help, i was able to source already some of this info in the yellow bible.
so i am planning to widen the inlet valve and enlarge the chamber according to vizard probably, also skim the head whilst i am at it to get cr down even further. taking into account my pistons are already elevated
There is some knowledge on what to do the 202 on this forum, in fact I think some people rate it above the 295 when worked.
It might be Vegard.
Advantage
Member #: 1450
Near Paris - France
Word of caution, skimming the head will RAISE the CR !
Good for N/A, bad for turbo !
You start with bigger chamber, CR goes lower.
You remove material from the chamber CR goes lower once more.
Then you skim the head to get at least the volume you use to have.
What would be the spec of the engine camwise ?
If it is for N/A street engine, I wouldn't spend too much time and money on the head ...
I am about ( within the next 2 years ...) to fit a similar head and a MD 256 on a 998.
I will unshroud the valve, remove the exhaust guide boss, skim it to get the dynamic CR the engine use to have (accounting for the intake closure difference between standart cam and MD 256) and I hope something in the direction of 55 bananas so hopefully on par with a low comp 1275.
I do that because I want to save my money and 12G295 for the turbo application.
If you are after big numbers, convert to turbo based on the 12G202.
If you are on a budget, fit a cam instead of new bigger valves.
Rusty by nature
What I've found is that the 202 has a potential to be just as good as a 295. There is material in the right places but it takes a lot of work/time/money. If you're confident in doing it yourself, a 202 will be very good. If you're paying someone to do it, the 295 makes more sense. I've had to do some 202s as three 295s cracked on me and they are becoming scarce.
Have a look here:
http://home.online.no/~lyngset/enginestuff...t=25&pDispType=
Advantage
Member #: 1450
Near Paris - France
Nice link.
Why the smart turbo picture ?
Anything under the blanket ?
Rusty by nature
pieter
Member #: 7577
belgium
@advantage, i'm gonna use it on a n/a engine
these are all parts i collected over the years and i want to make something out of it, for street purpouses and on a budget
that's why i want to try to do all the work myself, it would be a great experience and save me a couple of euros
Advantage
Member #: 1450
Near Paris - France
But do you do the machining yourself ?
Enlarging ports and chambers is all I can do so as I said, I'd rather spend 100 quid on a camshaft than on valves and valves seat cuts ...
I think it's more HP per £ spent ...
There is also an issue if using 1275 valves in a 202 head, they are too long (or short, can't remember), you can piss off Vegard !
Rusty by nature
