Home > Help Needed / General Tech Chat > Rear Brake Pipes
sturgeo
Member #: 1778
Northants
As i'm removing the brake pipe brackets from the radius arms and also need to replace the existing rubber hose section i was wondering if i single pipe from the subframe to the rear brake drum was available?
I've already got the 3 way and pipes that run to either end of the subframe.
I think there used to be one available, with a banjo fitting to go to the rear cylinder.
t3gav
Member #: 229
Gavin@minispares.com
kent
Most people sell the longer braided type with a banjo fitting but you could make up a copepr pipe easily enough.
sturgeo
Member #: 1778
Northants
Is this the correct thing?
http://www.minispares.com/Product.aspx?ty=...id=34303&title=
I've currently got http://www.minispares.com/Product.aspx?ty=...id=35296&title=
with the 2 copper pipes (1 short, 1 long) which used to join to these: http://www.minispares.com/Product.aspx?ty=...id=32711&title=
yep, those first ones are what you want,
sturgeo
Member #: 1778
Northants
Cheers lads, i'll add them to the order :)
so that replaces everything from the tee piece to the drum?
didnt thik they would be off the shelf, i need some too
no it fits from where the normal hose fits on the subframe to the wheel cylinder.
yeah sill me :( they would still do the job i want though8-)
