Home > Help Needed / General Tech Chat > Current ratings for Megajolt,Edis ,Coil pack and AFR gauge
tadge44
Member #: 2500
Buckinghamshire
I have a subsidiary fuse board with individual circuits for all the above, all fed from a separate fuse on the main fuse board.
My question is - what sort of current does each draw, so that I can wire and fuse appropriately ?
I have used 2a for the MJ and 10a for each of the others, pro tem, but this suggests I need to allow up to 30 amps on the main fuse board which seems a lot.
Suggestions and comments please.
The MJ, being basically electronics, will draw very little so 2A is fine. EDIS the same.
But the coilpack really needs a 20A fuse because of it's peak (charging) current. It doesn't draw 20A continuously but a 20A fuse will both protect it, and prevent you from blowing fuses at random.
The AFR gauge will draw about 2-3A when it's operating the built in heater in the LSU sensor, much less once the engine is warm.
So, for the overall package, 30A seems about right for a protection fuse.
Certainly nothing less than 20A overall with a coilpack or you could get random fuse failures.
(mine are wired independantly, 20A for the coilpack and 3A each for the electronics, widebands etc.)
tadge44
Member #: 2500
Buckinghamshire
I just knew you would be the man with the answers !!
Many thanks, I will wire and fuse accordingly.
What prompted the query was that I blew a 10a fuse powering the coilpack, which , now, its obvious why.
I have a feeling that the intermittent cutting of the ignition system that I had recently is something to do with it too.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Remember that fuses only protect the wire before the fuse not the device after it. e.g. if you are blowing a 10A fuse on a 5A wire you will need a fire extinguisher in no time.
http://www.twin-turbo.co.uk
tadge44
Member #: 2500
Buckinghamshire
Wise words but it is a long time since it was pointed out to me that fuses are only to protect the wiring and not the appliance and the advice has stuck.
Ben H
Member #: 184
It is just very counterintuative and most people get it wrong so worth noting for future searches.
Good point.
Both AES http://www.autoelectricsupplies.co.uk/category/10
and VWP http://www.vehicle-wiring-products.eu/VWP-...andardcable.php
(and probably others) have tables of the correct sizes of both "standard" and modern "thinwall" cable ratings to pick the right sizes from.
