| Home > Help Needed / General Tech Chat > Varley Red tops? | |||||||
64 Posts Member #: 8372 Advanced Member wickford , essex |
29th Jul, 2010 at 05:37:38pm
Hi all just a quick question ... im genna start to rearrange/organise my boot soon, and was going to fit a varley red top (im fed up with battery acid everywhere in the boot !)
29th Jul, 2010 at 07:27:29pm
Remember that you only need the battery to start. The alternator is what will be running all the kit.
http://www.twin-turbo.co.uk
29th Jul, 2010 at 07:57:56pm
ok yeah hadnt really thought of that ! its pretty obvious when you think about it :)
29th Jul, 2010 at 08:37:50pm
How much does a normal lead acid weigh approximately? On 11th Feb, 2015 robert said:
29th Jul, 2010 at 08:38:54pm
around 11kg .... |
29th Jul, 2010 at 09:25:21pm
I find a RT 15 fine with 12.5 compression. Ive not needed to charge it in over 2 years I seriously doubt it! |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
29th Jul, 2010 at 09:32:02pm
I think my PVR25 weighs 4kg or so, so a really worth while saving.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
30th Jul, 2010 at 07:51:34am
That's good to read Nick, I'd been looking at Powervamp, but was considering a more expensive one. Their site says 6.1KG, but if that's a heavy estimate then even better. On 11th Feb, 2015 robert said:
203 Posts Member #: 1734 Senior Member Lancaster |
30th Jul, 2010 at 08:34:39am
I have a powervamp pvr25 too. Had one for a couple of years and it's fine. Just had to make sure I was using a good quality 32mm2 battery cable. Being gel you can lay them on their side too, which is useful for fitting in confined spaces (under seats etc) |
30th Jul, 2010 at 10:26:06am
ok cool thanks guys , so i think ill start looking at a powervamp 25 instead then :)
30th Jul, 2010 at 01:16:42pm
im using a 55 amp one, running a metro heater, car stereo, megasquirt and facet fuel pump if thats anything to go by. |
![]() 673 Posts Member #: 1395 Post Whore chepstow |
30th Jul, 2010 at 01:50:43pm
Mine is varley red top 25 and it is fine for my car. My mate also has one in his b18 engined civic with quite high compression and its fine |
30th Jul, 2010 at 04:24:48pm
Tried the search-button?? On 13th Jul, 2012 Ben H said:
30th Jul, 2010 at 05:46:35pm
PVR25 for me also! On 5th Sep, 2011 Vegard said:
784 Posts Member #: 912 Post Whore North Yorkshire |
30th Jul, 2010 at 09:25:05pm
Don't waste your money on a red top.
I drill holes in everything..! |
30th Jul, 2010 at 10:47:32pm
25 it is then :) thanks guys ! :) |
