| Home > Help Needed / General Tech Chat > srs airbag lamps gone on | |||||||
239 Posts Member #: 7577 Senior Member belgium |
4th Aug, 2010 at 10:31:25pm
hi everyone,
5th Aug, 2010 at 06:50:46am
have you checked under seat connections, then the yellow ring under the steering wheel is well known to fail. |
5th Aug, 2010 at 07:15:24am
That won't work it - they have a chart for cars which should have an SRS light and if yours does not light then go out - that is a fail also! On 5th Sep, 2011 Vegard said:
5th Aug, 2010 at 08:01:42pm
i found it, the rotary coupling is broken off on the inside so if anyone has one lying around i'm looking for this
